cam questions
Old Dec 29, 2010 | 11:26 AM
pozesd99''s Avatar
Default cam questions
so i have a 1998 camaro z28 with 80k miles. runs very good now with my baby cam,but looking to step it up just a bit.currently the mods are 241 heads, custom cam 232/228, 603./.598 110 lsa. built 4l65e with 4k stall, 3.73 gears. with this set up it has gone 11.6 at 116mph. not bad for a car that put down 339rwhp through a unlocked converter.
so now i want to swith to a larger cam, 243 heads, and a fast 92/92 set up.
i was thinking about the tsp ms3 and or ms4 cams. how would driveability be with my stalled auto. any cams you would suggest.
i am also worried that if i get a bigger cam, i will run a slower et???
any help would be greatly appreciated..
Old Dec 29, 2010 | 03:00 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
It looks to me that you are mostly setup for a larger cam. I would not expect you to run a slower et with that sized stall and gears. You should still be able to get a good 60 foot out of the car and the larger cam should give you good mph. Driveability on a setup like that will really be up to the tuner for the most part.
