anyone tried this cam?
Old Jan 4, 2011 | 02:57 PM
time3777's Avatar
Default anyone tried this cam?
I have a 2005 a4 gto and am planning on installing this cam comp cam #54-456-11 duration at.50 219/227 lift .607/.614. What does everyone think?
Old Jan 4, 2011 | 03:04 PM
bozzhawg's Avatar
What heads? I assume LS2 w/243's?
Bozz
Old Jan 4, 2011 | 03:46 PM
time3777's Avatar
yes I still have the 243s, but will upgrade with dual valve spring kit.
Old Jan 4, 2011 | 04:11 PM
briancb1's Avatar
Its hard to say w/o knowing much else on your motor but it should be torquie within the stock rpm range.
Old Jan 4, 2011 | 04:28 PM
SNLPerformance's Avatar
our v3 is slightly bigger in a few areas, but would still work well with the stock stall if that is your plan...feel free to call the shop at 817-750-2000 to discuss things, Chris
Old Feb 4, 2011 | 05:45 PM
OldCobraGuy's Avatar
I'm going to give that a try in a stock bottom end LS1 with 243 heads...but I'm using 26918 beehives. Yea...I know...but I am not the first to use these springs with this cam. They work well with it. If I go to the light valves, I'm really golden.
Old Feb 6, 2011 | 01:58 PM
SweetS10V8's Avatar
Ive used that cam with the new 918s on probably 4-5 engines now. Great all round cam!!.
It made 46hp on the 5.3L I out it in last time on the engine dyno(Used 26926s here customers preference).
Ive also used it on 6.0Ls and with a decent set of heads they always make 490-515hp.
I also personally run almost the same cam in my personal vehicle. Except I picked the one with the larger exhaust for my LS3 heads (219/235) and I run 918s.
Old Feb 8, 2011 | 09:09 AM
SweetS10...you ever run into any piston/valve clearance issues with that much lift? Ever done one on a 5.7?
Old Feb 8, 2011 | 09:21 AM
RedVertTA's Avatar
What's the LSA on that cam?
Old Feb 8, 2011 | 01:48 PM
it's 112
Old Feb 9, 2011 | 05:10 PM
BORN2FLY's Avatar
Lift isn't the main ptv issue .... it's duration + ICL/LSA, as maximum lift usely occurs when the piston is a bottom dead center anyway.
Old Feb 9, 2011 | 05:41 PM
JustAnotherLS2's Avatar
Unless you are A. On boost B. Spray or C. L92 heads, There are much better options out there.
Old Feb 10, 2011 | 08:54 AM
Good point...
JustAnotherLS2...I would love to hear them. This cam appears to be one that takes huge advantage of the cathedral port design and has a very broad torque range. For street performance and manners, this appears to be very good. But I'm ALWAYS open to new ideas!!
Old May 29, 2015 | 10:02 PM
Luisdelvalle310's Avatar
By any chance does anyone on here have sound clips of this cam? I just purchased one and i would like to hear it. Please help
