L92 heads on stock cubes
Im building a 6.2 L92 right now
Besides, get a decent set of cathedrals and what manifold are you going to use? You're gonna have to drop some coin on a fast intake, throttle, injectors etc... Complete LS3 manifold, throttle body and injectors can be had for $300 online. Cathedrals can make great power, but your gonna have to spend some cash to be on par IMO
Stock L92 heads on a 6.0 block.
Yellow .......Cam 224/230 .581/.590 112 [HP]
Blue .......Cam 224/230 .581/.590 112 [TQ]
Red .......Cam 220/220 .581/.581 112 [HP]
Green .......Cam 220/220 .581/.581 112 [TQ]
Real world RWHP results in a 2006 GTO
LS2 6.0 Block
Cam 224/230 .581/.590 114
CR 10.4 (unmilled, untouched L92 heads)
LS2 6.0 Block
p.s. what are the specs on the stage II "bozzhawgn" that supposedly put down 473 rwhp?
Your response was the first of many clues that you've never worked on any LS, much less the junkyard LS2 that you supposedly put down 473 rwhp with using your "bozzfraudin" stage II cam. You're a poser of the highest order who's been called out on multiple boards for not being able to produce a dyno chart of his 473 rwhp LS2. Why? Because it's pure fiction. Plain and simple, you're a bullshit artist.
Let's take a look at the caliber of real racer that we're talking about here - You replaced your BBC with a junkyard LS2 because you couldn't fix a few leaking freeze or make any power with the 468 cubic inch motor someone else built for you. Now you're specing cams and doing "complete conversions"? HAHAHAHAHA.
Here's a hilarious exchange between you and your engine builder -
http://www.yellowbullet.com/forum/sh...2&postcount=48
If anyone bought an engine and less than 1 month later it leaked coolant out the freeze plugs and oil out the rear main seal, its not a issue of can I fix it, the issue is it was built shitty..... And he admitted that was his fault, and no he did not garuntee the warranty. poor business... That has nothing to do with or your ability to cut and paste..... Coolant leaking out of the freeze plugs is from weak cylinders shifting and not properly sonic checking the block or movement or poor mechanical assembly which is way over your head..... This is why I never bought engines long distance and the first time I did the block didn't last...... That has nothing to do with my mechanical alptitude....... It was a shitty build...... Then we found out that this guy was running scam all the time... And when we found out, we busted him and are still seeking legal action....
Then, after pulling your leaky BBC that you never could get running correctly, you tell your engine builder that you replaced it with a LS2 that's putting down 473 rwhp. Immediately, several people in the forum threw the BS flag and requested that you to post a dyno sheet that you've never been able to do. Why? Because it's pure fiction. You haven't been able to provide a dyno sheet for months.
WHAT ARE YOU HIDDING MARK?
http://www.yellowbullet.com/forum/sh...&postcount=446
