Eliminating Valve Float
Old Jan 9, 2011 | 12:40 PM
Marble_Sharp's Avatar
Default Eliminating Valve Float
I am looking for advice from someone who has experience with similar set-ups to mine. I am getting valve float over 6,000 rpms. Below is my current set-up. Need recommendations on good springs that people have had proven success with on similar set-ups. This set-up is currently N/A. May add a 200 shot of nitrous down the road.
heads - PI/Mast Big Bore LS7 heads
http://www.mastmotorsports.com/2010/... - Bare&id=359
intake valves - from Mast Motorsports
http://www.mastmotorsports.com/2010/...=Valves&id=169
I think these are the exhaust valves, I don't believe they are hollow stems.
http://www.mastmotorsports.com/2010/...=Valves&id=161
Lifters = morel link bar limited travel
Rockers - T&D adjustable shaft rockers - 1.8
Cam - 243 247 LSL 112+4 .661 lift
Old Jan 9, 2011 | 01:30 PM
TurboBuick6's Avatar
What springs are in it now?
Old Jan 9, 2011 | 03:40 PM
These ones from MAST -
http://www.mastmotorsports.com/2010/...Springs&id=183
Old Jan 9, 2011 | 04:20 PM
fuel's Avatar
hydro or solid roller
Old Jan 9, 2011 | 04:44 PM
Hydraulic - Morel limited travel
Old Jan 9, 2011 | 04:50 PM
fuel's Avatar
im only guessing, maybe the lifters are calapsing
Old Jan 9, 2011 | 05:24 PM
3pedals's Avatar
NEED to know what springs MAST installed on your heads. springs are VERY important.
Old Jan 9, 2011 | 05:29 PM
SweetS10V8's Avatar
Lighter valvetrain.
Need to know what springs you have and how they are setup.
Rockers are heavy pigs, swap to oem rockers and try it out.
Old Jan 9, 2011 | 05:41 PM
All I know about the springs is what I posted in post #3.
I agree springs are important and I am certain they are the problem. That is why I am looking for input on what springs others have used successfully with similar set-ups.
Old Jan 9, 2011 | 07:01 PM
Gray86hatch's Avatar
what are the installed specs on the spings? What PR. How much preload on the lifter.
Tim
Old Jan 9, 2011 | 10:16 PM
Sdunn's Avatar
What engine do you have these heads on? What intake and fuel set up are you running?
Old Jan 9, 2011 | 11:56 PM
ramairroughneck's Avatar
Sorry to get off topic but how much compression are you running? E85? I am really impressed with the rwhp given the problem. Thats an awesome number to put down by only 6100 rpms. Most guys cant get that even with larger cams. Good luck and keep us informed.
Old Jan 10, 2011 | 10:50 AM
Tim
Sorry, but I don't know the answer to these questions. This stuff was done by a shop.
Old Jan 10, 2011 | 10:51 AM
LS7 engine, FAST 102 intake, NW 102 Throttle body, 8.1L bucket.
Old Jan 10, 2011 | 10:53 AM
I think the compression is around 11.5.
Pump gas - 93 octane.
It is a M6 with 4.10 gears.
Old Jan 10, 2011 | 01:11 PM
cam's Avatar
cam
I have no "proof" per se but seeing as there are simply not that many spring manufacturers out there the MAST springs appear mighty similar to PAC springs which are very good quality. Considering this;
Im agreeing with above. Ditch those heavy *** rocker arms for some stockers and see how it goes. Its a cheap, fast, and simple thing to start with. If that doesnt do it then lighter valvetrain is probably your answer but still... Lots of guys revving the **** to 7K RPM on solid valves without issues so?
Old Jan 10, 2011 | 01:48 PM
fossil's Avatar
I agree with Cam. I had a 6.0 with aftermarket heads, springs, retainers, and rocker arms, and at 6,200 rpms full throttle at track would will feel like a engine miss or skip, real bad on 2-3 shift. Come to find out was valve float, replaced rocker arms with factory rockers and never had problem again.
Old Jan 10, 2011 | 04:02 PM
I would stuggest checking the springs to see what the pressures are first. 150-400 at least is needed.
How was the tune I have seen that cause issues that look like valvetrain issues.
Tim
Old Jan 10, 2011 | 05:20 PM
Thanks for all the input.
What I am really looking for is someone with experience with similar set-ups to tell me / sell me some proven springs.
Old Jan 10, 2011 | 05:37 PM
Those springs should be fine, I know who's they are. How close to coil bind did you engine builder set em to?
What type of retainer are you using?
