L92/Lq9/other?
I am just looking at some of you guys' opinion on setups. I don't have money for a 408/etc so it will be of a more budget built but want something I can grow on.
Looking to spend around 3K for the time being. The MAIN question right now is which block? I am pretty positive I want to go with Ls3 heads.
L92/Lq9/etc...
Here is my book.... Too much info is better than not enough.
I will break it down in a way that I think would be easiest for me to give the best answer.
Current setup/numbers/times
Stock bottom end ls1
ported/milled 317s
custom 226/228 .588 114
ported FAST 102/92
Stock MAF (will be moving up to a larger diameter MAF/lid later)
Kooks LTs/TSP Xpipe/1 chambers before axle
Chrs1313 Ram air
PTC 4000 (built 4l60e)
3.73 (stock 10 bolt) I will have a 9" shortly so no worries there
Nearly full BMR adj. suspension (dont have drag bar or front shocks yet)
Plate kit/Nano
Race weight is around 3450#... Nothing has been removed, I run Prostars at the track and I will not be removing any weight in the future..
Before the Xpipe/intake/tb/chrs1313 were added I had a nitrous tune on it and on a low dyno I did IIRC- 372/350
I put on the intake/TB and still had a nitrous tune, with no tuning at all I dynod (still on the low dyno) 380/365.
Before the xpipe/intake/tb/chrs1313 I was running consistent 7.3Xs@94mph 1.50-1.52 short times BARELY spinning the tires over. DA was around 2000+ (which seems to almost always be between 1500+ - 2500+ at my track).
Goals.....
As far as dyno numbers go, I could care less... I guess on a normal dyno if I had to pick a number I would shoot for around 475Rwhp?
Track times..
Motor- Consistent 6s.. Since my DA doesn't change too much at my track it shouldn't be too hard. I think with my new intake/tune/exhaust I have I would have been at a solid 7.1 in 1500+DA or so. I would love to see a personal best of 6.7X with the new setup..
Trap I don't care too much about, I would like to see 96+mph pretty regularly though and with good air 99 maybe. I don't know 1/4 times too well but consistent mid-high 10s@123+mph I think is what that would equate to.
Nitrous- low-mid 6s.. I am pretty sure my converter might play a roll in holding me back here. It isn't on the loose or tight side for a 4000, pretty much right on where it should be but I think might be too loose to spray a big enough shot to get me into the low 6s. I would be happy with 6.4X@105 or so. I have never ran that quick/fast so I don't know what to expect exactly. I would like to keep the shot at a maximum of 175 (I would do a 200 for a personal best maybe once a year for one pass) but I think 90% of the time I would have it jetted for a 150 hit. 150 shot would be the biggest on the street if I were to use it... I would run around with 100 jets in but probably only use in once every 2 months or so for maybe 2 races 40-130. Not too many street cars in my area that would be able to mess with me on motor, few bikes I like to play with here and there though. Again, not too keen on 1/4 times but I think bottom 10s-high high 9s @ 135 or so is what that would equate to?
I don't want a dedicated motor or nitrous car. I don't want to run 7.3s on motor and 6.2s on a 200 shot... Other hand, I don't want to run 6.7s on motor and 6.4s on a 10 shot. I want a happy medium somewhere in there.
I am up for changing anything, converter/exhaust/gears/tire size/intake/heads/etc etc etc....
Hopefully I put all that so it got my goals across... Talk it up!!
Also....
I can get a low mileage Lq9 for 1,300$
low mileage L92 for 2,200$
Can't remember the name, aluminum 6.0 (ly6) 1,800$
These are EXTREMELY low mileage/6 month warranty/shipped to me...
What would the power difference be with the prc 2.5 heads and ls3s? I know the cam selection will be greatly different.
http://www.lingenfelter.com/mm5/merc...gory_Code=C163
You don't need alot of cam to make the L92 headed motor run. Call up Geoff@EPS or Patrick G and get something spec'd or you can just get something off of Geoff's site or TSP's L92/LS3 specific cams.
As far as the motors, I would choose the L92 since you would get the heads with it and those heads flow a ton and if you go bigger the heads will be right there for you. No need to buy bigger heads with them.
Lq9 is definitely cheaper and easier but I would love those few more cubes and the saved weight. I wanted an l92 to begin with.
What intake would you guys run?
I bought an L92 motor and building a 418 with it. TSP sent me everything I needed to convert it over. Cost me a lil over 300 bucks.
