Pics of LSA Heads.
Old Jan 29, 2011 | 07:35 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
From what I've read they're an identical copy of the LS3 casting aside from the wing and casting process. The LS9 head is the only one with the thicker deck.
Old Jan 29, 2011 | 08:59 PM
1CAMWNDR's Avatar
Originally Posted by NemeSS
so the heads pictured are around 220$ price bare?
they look like they dont have any angles machined in the the seats yet.
Those seats look stock to me. With a single cut for the valve to sit on.
Old Jan 31, 2011 | 09:24 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
They have at least 2 angles milled onto the seats. Depending on how you count, there could even be 3. The seats are machined just like a std head from GM.
Originally Posted by dmracing
Does GM use them finished like this or do they cnc the runners. Do you know the flow as cast?
Gm uses them like this. GM does not cnc this head in any fashion.
Old Jan 31, 2011 | 05:31 PM
v8pwr's Avatar
John , you guys should offer these CNC'd . I'd really like to see how much they would cost with the lightweight valves .
Old Feb 4, 2011 | 07:20 PM
Kory 88Iroc Lt1's Avatar
Is the wing that is refered to, the small bump at the base of the valve guide boss? From what I've been able to gather these are supposed to flow the same as an ls9 head. Is that bump all that reduces the flow from the stock l92 intake flow numbers?
Kory
Old Feb 5, 2011 | 11:46 PM
TheRooster's Avatar
Originally Posted by litle88
John thanks for those pics, but what is the difference those and the Ls3's?
Is there more meat on them for the boost? What valves come with them
Yes, the deck is a little thicker and they are stronger overall because they are rotocast to eliminate porosity during the pour and they are T356-T6 aluminum. Valves are 2.165, 1.59 and they also have a "wing" in the intake port to help atomize fuel.
Old Feb 5, 2011 | 11:48 PM
TheRooster's Avatar
Originally Posted by v8pwr
Is the LSA casting stronger than the LS3/L92 casting ?
Yes, about 20%
Old Feb 7, 2011 | 10:16 AM
NemeSS's Avatar
There worth the $ IMO for budget forced induction build
Old Feb 9, 2011 | 08:36 PM
v8pwr's Avatar
Does anyone know the part # ? All I can find is the assembled head .
Old Feb 23, 2011 | 03:07 PM
cjmatt's Avatar
Anyone know what the chamber cc is on these?
Old Feb 23, 2011 | 06:02 PM
v8pwr's Avatar
I'm pretty sure the combustion chamber is the same as an LS3 . I've been trying to get more info but they've been working hard dealing with the loss of John . I really need heads and misc. parts to finish my 402 build .
Old Feb 27, 2011 | 08:52 AM
  #32
See5's Avatar
Default Re: LSA heads
Complete LSAs are are significantly better for boosted or HO applications for a number of reasons.
They have a stronger , more dense alloy and casting process.
They have tougher, more heat resistant valves and they have that swirl inducing wing cast into the roof of the intake ports.
The LSA engine as used in the CTSV and the new LSA powered ZL1 Camaro are both supercharged and benefit from these heads as supplied.
The low cost of the bare castings is more than offset by the final assembled cost of the heads inluding the special valves, spring retainers and rockers (rockers same as sister rectangular port offset valve LS3, L92, heads)
The concept of the LSA and LS9 heads is optimize them for boosted applications where porting is not the answer rather more forced induction pressure and better mixing.
IMO
Bruce
From GM:
Exceptional airflow
High-flow cylinder heads based on GM’s proven L92 design channel incoming air into the combustion chambers. They are made with a premium A356T6 alloy that offers excellent heat resistance, particularly in the bridge area of the cylinder head, between the intake and exhaust valves. Additionally, each head is manufactured with a roto-casting method.
Also known as spin casting, the roto-casting process involves pouring the molten alloy into a rotating mold, for a more even distribution of the material that virtually eliminates porosity – air bubbles or pockets trapped in the casting – for a stronger finished product.
For optimal combustion, the cylinder heads feature swirl-inducing wings cast into the intake ports, improving the mixture motion of the pressurized air/fuel charge. The gatekeepers of the heads’ combustion chambers are large-diameter, 2.16-inch (55 mm) intake valves and 1.59-inch (40.4 mm) exhaust valves. The intake valves are made of steel and feature thick heads. Unique, four-layer steel head gaskets are used between the heads and cylinder block.
The LSA’s valves are actuated by a hydraulic roller-type camshaft that delivers a relatively low 0.480-inch (12.2 mm) lift on both the intake and exhaust sides. The low lift – relative to the engine’s high horsepower and torque – and low overlap foster a smoother idle and excellent low-rpm driving characteristics. The wider efficiency band of the Eaton supercharger enabled the use of the low-lift cam to achieve the engine’s performance targets.
