Pics of LSA Heads.
Normally if you are going to get them machine, it will cut off all the possible flow problems that are there.
The main issue is the vane/step that is in the intake side.
Here are some pics of the heads.
and the valve valley
Chambers
And exhaust port
It does not look like there is alot of problems behind the valve on the seat transition either.
The LSA head is supposed to be thicker on the deck, but is also a diff head casting than the LS9. They use a std size head bolt as well.
Having them ported, they are a cost effective alternative to the LS3 head bare.
They use the same exhaust valve as the LS3, but use a different intake valve. They are still the 2.165 1.59 sizes.
The bare head is a little less than the ls3 bare head is, so it is a better option for keeping cost down when having them sent off and cnc. Alot of customers like to purchase the bare head and build as needed. We do not offer these cnc yet.
I edited my post to make it more clear.
"The LSA heads feature a unique “wing” cast into each intake port to promote a swirling motion that blends the pressurized air-fuel charge. The heads are also cast from a premium A356-T6 alloy, which better manages the heat generated in a supercharged engine. A356-T6 pays particular dividends in the thin bridge area between the intake and exhaust valves, where effective heat dissipation is crucial to both performance and long-term durability. Finally, the LSA heads are rotacast. This process rotates the head mold as the molten alloy cools and essentially eliminates porosity, or microscopic pockets of air trapped in the casting. Rotacasting delivers a stronger part that helps maintain performance and structural integrity over the life of the engine."
