displacement on demand?
Old Jan 28, 2011 | 11:20 PM
383k5's Avatar
Default displacement on demand?
I'm looking at picking up a 6.2L from an 09 GMC Denali. I'm going to be running it as a standalone system so I was wondering if it has displacement on demand and/or Variable Valve Timing. I'm guessing it has VVT but how can I tell if it has DOD or not?
Thanks.
Mike
Old Jan 29, 2011 | 05:54 AM
Goldhawg's Avatar
I have similar ?. Is there a link out that says which LS engines have DOD so I can avoid these while purchasing an engine?
Old Jan 30, 2011 | 12:58 AM
rsz288's Avatar
There is a GM web site that has lists of car and truck engines.
For example:
http://media.gm.com/us/powertrain/en...08/08truck.htm
Old Jan 30, 2011 | 01:43 PM
Jimbo1367's Avatar
I wouldn't hessitate buying a DOD LS engine if the price was right. You would want to delete the DOD, which is easy enough. L92s don't have DOD. I am not sure about the newer ones though. L9H = 2009 L94 = 2010
Old Jan 30, 2011 | 03:56 PM
TransWS6Am's Avatar
only way to tell if its DOD is to pull the valley cover off. Even if it is DOD its easy to remove the DOD. Maybe if u have the VIN for the Denali you can look up the RPO codes and see if its DOD? Either way if the price is right, buy that thing.
