Titanium vs. SS valves weight...pictured...
Old Feb 5, 2011 | 10:45 AM
miami993c297's Avatar
Default Titanium vs. SS valves weight...pictured...
The compared valves are for my ETP modified 240+ cc with the following dimension:
- Intake 2.100 x 5.450 x 5/16
- Exhaust 1.570 x 5.450 x 5/16
The weight difference is as on the pictures below:
REX SS Intake:
Xceldyne Titanium Intake:
REV SS Exhaust:
Xceldyne Titanium Exhaust:
Result:
Christian
Old Feb 5, 2011 | 11:10 AM
SHovV's Avatar
what are the benifits of titanium ov ss other than weight?
Old Feb 5, 2011 | 11:54 AM
ramairroughneck's Avatar
Better valve control. Less likely to have valve float
Old Feb 5, 2011 | 12:00 PM
Revving high rpm on aggressive camshaft producing decent hp on an hydraulic daily driver:
Christian
Old Feb 5, 2011 | 12:20 PM
Stang's Bane's Avatar
What kind of power did it make Christian?
Sounded great!
Old Feb 5, 2011 | 12:35 PM
Sounded great!
Lost the thread on LS1 hrdc...for ever I guess.
As on the engine dyno
Christian
Old Feb 5, 2011 | 12:45 PM
vette0009's Avatar
Is that a solid roller valve train ?
Old Feb 5, 2011 | 12:46 PM
As written in post # 4:
Hydraulic.
Christian
Old Feb 5, 2011 | 01:11 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Are there any wear concerns when it comes to the valves or the valve seats?
I must say - Barbara Streisand sings very well at 7500 RPMs.
Old Feb 5, 2011 | 01:20 PM
The valves were coated "to suit unleaded fuel and steel valve seats"...it's what they wrote on my invoice, but the process is nothing secret.
And I am not bored to listen to the same song everyday!!!!!!!!!
Christian
Old Feb 5, 2011 | 05:01 PM
djjonesivs's Avatar
incredible !
Old Feb 5, 2011 | 06:51 PM
kapke13's Avatar
Sounds really good!
Old Feb 5, 2011 | 07:15 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Was the engine ran with the SS valves first?
Old Feb 5, 2011 | 07:21 PM
Care to share details of the rest of the valvetrain? Rockers, lifters, springs.
Old Feb 5, 2011 | 07:29 PM
Valve-float or valve-train instability starting at 5800 rpm and power falling on its nose at 6200 rpm...
Christian
Old Feb 5, 2011 | 11:48 PM
Congrats. It holds the power beautifully.
Old Feb 6, 2011 | 10:37 AM
SHovV's Avatar
will titanium vales hold up to nitrous and boost like ss valves are know for?
Old Feb 6, 2011 | 11:12 AM
cam's Avatar
cam
Purrin like a kitten all the way! What valve springs you running?
Old Feb 6, 2011 | 11:23 AM
slowride's Avatar
What cam lobes, rockers and lifters are you running? Very long peak powerband and it doesn't drop like a rock either. Very nice.
Old Feb 6, 2011 | 04:36 PM
- OEM LS6 Rockers Comp Cam Bearing upgraded by SStrokerAce
- PSI LS 1512 ML Valve Springs
- Xceldine XRE52S Retainers
- Xceldine XLO992-C Titanium Valve Locks
- CV Products CV8050 Push Rods. 8.050 x 3/8 x 0.080
- Morel MRL 4708 Hydraulic Hi-Lift LS Roller Lifters
- GM Hydraulic Lifter Guides
- Camshaft by Ed Curtis FTI, I asked him how I wanted the engine to behave, where I wanted my power to be, he send me the Barbara Streisand Camshaft tailored for my needs...
The only way to have the cam-specs was to "cam-doctor" it...which I did but will not share by respect to Ed work.
Mainly smaller than it seems, and a lot smaller than some others around here, with not that much of lift...
Christian
