l76 dod lifter rattle
Has anyone com across this problem before and if so does this mean that valves have hit pistons or would it be just lifter rattle.
the valve train etc is all original except for 600lift springs.
I am thinking to refit my original valve springs until i am ready to fit cam and change the lifters.
Any input would be great
Thanks
thanks i am going to return the stock springs tomorrow and see what happens
When you do the cam swap. Are you going to remove the DOD plate in the valley, and tune the ecm? If you don't. It will set codes, and try apply oil to them.
I have already changed the valley plate to try and solve that problem of running on 4, so all good there just waiting for head gaskets and lifters to change them out.
Thanks
If it were me I would make sure the cam is in good condition before dropping a new set of lifters on top of it. It would suck to have to change them twice.
