Head Stud Q...
Old Feb 16, 2011 | 09:35 PM
S10xGN's Avatar
Default Head Stud Q...
How tall are the larger ARP (11 mm) studs as measured from the deck surface to the exposed tip?
Old Feb 17, 2011 | 08:02 PM
S10xGN's Avatar
Anybody have a set of ARP's and a bare block laying around?
Old Feb 17, 2011 | 09:35 PM
Gonoma's Avatar
I do its an 02 block though if that matters to you since they have the two different length bolts/studs
Old Feb 17, 2011 | 09:46 PM
S10xGN's Avatar
Dan,
It won't matter, all the large studs will stick out the same length (just that your 4 longer ones will set deeper in the block). I know my heads have been milled a bunch and I don't have gaskets yet, but my studs look to have an excessive amount of threads showing when the heads are sitting in place...
Old Feb 18, 2011 | 07:39 AM
Gonoma's Avatar
Ill see about getting you a measurement today then.
Old Feb 19, 2011 | 09:45 PM
Gonoma's Avatar
im getting right at 2 3/8"
Old Feb 20, 2011 | 07:19 PM
S10xGN's Avatar
Dan, thanks for checking!
I'm seeing 1 1/4" to the shoulder and 2 5/8" overall height. These would be the no-name E-Bay specials. No flames please, this will be a n/a motor and I don't like torquing steel bolts into aluminum threads. Aside from being longer, these are nice looking pieces. My main concern is possible interference with headers, but that'll be much later.
Old Feb 20, 2011 | 07:34 PM
Gonoma's Avatar
anything I can do to help
