What rockers for bigger cam in LS3?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Going to be installing a bigger cam in a LS3, will the stock rockers be fine, or should I upgrade to the Harland Sharp L92 Roller Rockers?
http://www.harlandsharp.com/ls1.htm
This will be a street car that won't see much rpm above 6,500k unless I'm having a little fun and I will be only going to the track 1-2 times per year.
I've done a little searching but doesn't seem too many people put cams in the LS3 like they do LS1's.
Bill
Bill
you could just do the trunion upgrade and save some cash.... http://www.hinsonsupercars.com/p-107...n-upgrade.aspx it says LS1 but they work on any LSX.
Richard at WCCH has some very nice "bushed" stock rockers. They're bush with unobtanium and gets rid of the needle bearings entirely.
I run YT's and I've had one break. They quickly replaced them all explaining they had a few bad run sets get out. I'm still a little leary of them and will probably go to T&D or Jesel.
Mast makes some. They go for around $450.
L92/LS3/L76/L99 1.7 Shaft Roller Rocker Arms
They've got them in 1.7, 1.8, and 1.85 ratios... non adjustable and adjustable.
Yeah we run them up to maybe .625ish and 450 ish open but have gone a wee bit further and they still worked fine. We do some much higher lift and higher spring pressure stuff so we use aftermarket on those.
