What should be my total timing
Old Feb 27, 2011 | 07:27 PM
deangoodin's Avatar
Default What should be my total timing
I am building a ls2 carb race motor ,11.1 compression ,will be sprayed,has 58 tooth on the crank using 6012 msd box,what is usably the total timing set up on motor no nitrous just on motor.my sbc and bbc motors ran good between 35 to 40 degree on motor ,is ls motors different????
Old Feb 27, 2011 | 08:15 PM
S10xGN's Avatar
Pump gas carb'ed LS motors seem to like around 36° total...
Old Mar 1, 2011 | 03:28 AM
Gaz05's Avatar
You got to be joking, you must have 23deg heads on it...... most are 26 to 28 max, you can use 36 but you wont have an engine for long.
Old Mar 1, 2011 | 05:08 AM
hymey's Avatar
carb or not the chamber is the same 28 tops. It might got 30 but after that u will lose hp very fast.
Old Mar 1, 2011 | 09:25 AM
allblowdup's Avatar
ls3 engines will make best power close to 30 but won't last that long at that. We run 28 deg and WOT for periods of 40 min straight on Av gas or 26 on premium at 2000ft. Anymore and the pistons go bye bye.
Old Mar 1, 2011 | 09:08 PM
S10xGN's Avatar
You really should hang around in the carb forum where you'll hear from peeps who actually have experience...
You got a carb'ed LS motor? Don't bother giving advice if you don't, cause you're just rehashing someone else's cr@p. I do have a carb'ed LS motor, and it does like 36° "mechanical". I also have another 14° "vacuum" advance added by a MAP sensor for 50° total. FYI, the longer manifold runners and relatively poor fuel atomization require more advance than an equivalent port injected engine.
Old Mar 1, 2011 | 09:33 PM
IDRIVEAG8GT's Avatar
I would not argue with this man. Cheers yo. FYI, Fuel injection LS engines with that compression range anywhere from 18* to 23* with a clean setup at WOT, unless you are boosted.
Old Mar 2, 2011 | 05:23 AM
Gaz05's Avatar
Yes I have a carb LS7 engine, have dynoed it twice, I can tell you exactly what timing is best.....yep, you can run 50deg at light throttle for fuel economy, no probs. If your LS engine requires 36 total timing at WOT to make power its not real efficient. As a matter of fact I just come from the dyno right this minute and I can tell you this particular LS engine wont take any more then 28 deg either. FYI you better go get some real experience.
