What intake should I run with 500+ cubic inches?
Old 03-08-2011, 08:24 AM
racejunky02's Avatar
Default What intake should I run with 500+ cubic inches?
I am thinking about using the LSX tall deck block and building a naturally aspirated 500+ cubic inch motor. What is the absolute best flowing intake out there? I know some of you guys have done some big cubic inch motors, which intake did you run?
Old 03-08-2011, 08:27 AM
tim99ws6's Avatar
going to need custom intake for something like that. Maybe a Marcella cast intake.
Old 03-08-2011, 09:41 AM
1CAMWNDR's Avatar
Mast Motorsports CNC single plane.
Old 03-08-2011, 05:00 PM
Gaz05's Avatar
Smile
Agree, if carburetted use the one with the Dominator 4500 pattern.You will need it..
Old 03-08-2011, 05:43 PM
LPE 403's Avatar
Marcella is going to put one together for my N/A 460. U keeping the tbody or going carb? Wont argue with single plane if going carb. Might make a few more ponies but John's intake are pure eye candy....
Old 03-08-2011, 06:42 PM
2000_SS's Avatar
^ truth
Get a Marcella or look at the cast manifolds from Cary @ Performance Inductions
Old 03-08-2011, 09:16 PM
ramairroughneck's Avatar
Beck, Marcella, or Mast are gonna be the favorites. Holley has some nice intakes coming out as well. Some of these will require you to cut the cowl on your Camaro though.
Old 03-09-2011, 02:46 PM
Thanks for the info guys I appreciate it, this build will be a while but what kind of power can a man make with 500ci and still run pump gas?
Old 03-09-2011, 03:17 PM
LPE 403's Avatar
Waaaaaaaay to many combo's out there to narrow in on a number. Stick? Auto? Intended use - street, strip? Solid? Hyd? Etc, etc... I can see 650-800 at the wheels.
Old 03-10-2011, 07:12 AM
Its gonna be a stick used mainly for the street and def hyd, I was thinking the same hp numbers but I am hoping for the high side of that margin.
Old 03-10-2011, 05:47 PM
Hard Core Z28's Avatar
Marcella or mast would be my choices.
Old 03-15-2011, 03:39 AM
MotoFreak's Avatar
No heads out flow the LS7 heads
Old 03-15-2011, 03:46 AM
odarabla's Avatar
This is untrue!!
Old 03-15-2011, 03:50 AM
odarabla's Avatar
Gm makes a carburated style intake that might work nicely with your build but I do agree with some of the above post.. A Edle Brock or a custom job would for the $$$$
Quick Reply: What intake should I run with 500+ cubic inches?
