PR Length doesn't seem to measure right?
-Bo
You can try different oil to help quite the valvetrain. The old LS1 liked Castrol Syntec 0W-30, but it always had that sewing machine sound to some degree. Probably in the cam profile. Larger cam in the LS3 is nice and quite.
Good thing you checked the preload
DJ
DJ
That makes me feel better, as LS7 HG's are .051 compressed correct? You have around .010 difference than me then. I think I might have went a little overboard trying to keep the lifters solid as I really am not sure how much the LS7's pump up but I'm going to run a 160 or 180 stat and a little thicker oil than the 5-30, as my oil pressure isn't where I'd like it after the oil reaches 190* or so. Maybe that will quiet it some upon getting to operating temp.
I chuckled when I read your post, don't be scurd of it hauz......
When you punch it and go sideways on a 70 MPH freeway with cars on the road, thats a time when you need to be scurd.....lol then and only then will you truly respect the power......
Bozz
Bozz
Anyway, going to drive it all this week so the oil change should be coming pretty quick, I need something that isn't going to thin out as much upon warming up. I'm thinking of first trying an 0w40 or 5w40 blend. And if that doesn't seem to do it I'll go with the Mobil 0w50. Are you running short travel morel lifters?
Barrett
using this page as a bookmark for when i measure my pushrods. i went from ls7 lifters to morel 5206 and had my heads milled .015" when i take the slack out of the rocker arm i get just over 2 turns be for the bolt stops.
