Cam ?
Old Mar 28, 2011 | 08:55 PM
dmracing's Avatar
Default Cam ?
Does anyone know if a 243/251 @ .050,.625/.625 on a 114 will fit in a stock LQ4 with L92 heads?
Old Mar 28, 2011 | 09:32 PM
TransWS6Am's Avatar
thats quite a large cam for 6.0 liters and L92 heads, L92 heads respond well to more mild cams.
Old Mar 28, 2011 | 10:27 PM
3pedals's Avatar
you'll need to flycut the pistons for PtoV, but otherwise an LQ4 doesnt have enough compression for that cam to run right, unless you take a BIG cut out of those heads
Old Mar 28, 2011 | 11:37 PM
HoLLo's Avatar
I agree. I'd say subtract about 7-9º of duration to get some more power under the curve
Old Mar 29, 2011 | 10:08 PM
dmracing's Avatar
The motor is actually 420 cubes.
Old Mar 29, 2011 | 10:19 PM
TransWS6Am's Avatar
If it's a 420 than that cam would probably do fine IMO.
Old Mar 29, 2011 | 11:30 PM
HoLLo's Avatar
A stock LQ4 certainly isn't 420ci.
Old Mar 30, 2011 | 04:13 AM
dmracing's Avatar
I know, the cam was picked for the stroker. I was gonna use it for know in a lq4.
Old Mar 30, 2011 | 06:26 AM
87silverbullet's Avatar
You are going to need big *** gears and stall for it in a stock cubed lq4. The lq4 is only 9.4:1 compression stock so if you do use it, it will be a dog of a motor.
I was spec'd around that same size cam for my 416 stroker from EPS.
Old Mar 31, 2011 | 01:08 AM
briancb1's Avatar
I like how you have all custom parts and your asking us, over the internet, if it will fit. Yea....
Old Mar 31, 2011 | 08:52 PM
dmracing's Avatar
Originally Posted by briancb1
i like how you have all custom parts and your asking us, over the internet, if it will fit. Yea....
I was simply asking if anyone put a cam this size in a stock lq4
Old Mar 31, 2011 | 09:29 PM
TransWS6Am's Avatar
dude, stock lq4 or 420? which one is it.
