Non stock Ls1 swap to Ls2 questions
Hi i have a few stupid questions, that i cant seem to find any info on through searching.Some i found mixed info on. I have a Ls2 block out of a 06 Gto that im about to swap into my 99 z28. I want to swap everything from my ls1 to the ls2.
I also have a set of Prc 2.5 5.3 heads on my camaro. Here are the Specs > http://www.texas-speed.com/shop/item...id=84&catid=40
1 & 2. Im wanting to know if those heads will work on the Ls2? and if so will it hurt the performance or make it any better? Or should i put the stock 243s back on?
3. Will my Fast 90 intake fit on the ls2 ok <<< this i believe will work fine.
4. Will my Mac Mid length headers work?
5. Will my 228R cam work in the Ls2? (even though ill probably go bigger) just curious
6.Will my stalled 4l60e work ok with the Ls2?
Thanks for any help/input hope this thread is in the right section.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Alright i found the answers to questions 3-6 which is yes to all of them. ![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Cant find anything on if the heads will work with the Ls2 block. Im almost sure they will bolt on but im assuming they will hurt the performance?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
