ls3 ls9 head gasket
Old Apr 19, 2011 | 08:15 PM
red 454's Avatar
Default ls3 ls9 head gasket
is the ls9 head gasket thicker then the stock ls3 gasket ??
i have a stock ls3 with a htv2300 on 10 psi
and when i remove the heads in the future would like to put a better gasket on and lower the comp a bit
thanks
Old Apr 20, 2011 | 06:16 AM
rsz288's Avatar
thanks
IIRC its the same thickness. The bolt holes are sized for larger bolts FWIW.
Nice setup
Old Apr 20, 2011 | 06:31 AM
red 454's Avatar
ok thanks for that
