help me delete vvt (newb)!!
Old Apr 26, 2011 | 09:16 PM
1BADMC's Avatar
Default help me delete vvt (newb)!!
hey guys, i picked up a 2010 L96 engine and it has vvt and i just need a very specific breakdown of the parts needed to delete it. The cam is wiped out on one lobe due to a broken lifter so i am obviously replacing the cam so that is not an issue. Thanks for all the help!!
Old Apr 27, 2011 | 09:27 AM
cam's Avatar
cam
Start here in the sticky
https://ls1tech.com/forums/generatio...-l92-info.html
Old Apr 27, 2011 | 10:03 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Why not keep the VVT technology and make some extra area under the curve!?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 27, 2011 | 10:23 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
My thoughts exactly
Old Apr 27, 2011 | 10:43 AM
Originally Posted by Schwanke Engines
My thoughts exactly
Glad more shops are getting on-board with VVT! It's great technology, and it seems the shops recommending deletion simply have not tested it or tested a bunk combo, it didn't work, and now they're back to deleting.
__________________
Old Apr 27, 2011 | 01:17 PM
1BADMC's Avatar
thanks for the thoughts, but i don't know a whole lot about it and im building the motor myself. what are the vvt cam selections like??
Old Apr 27, 2011 | 01:31 PM
We've got quite a few VVT camshafts to choose from! The quickest stock bottom-end NA 2010+ Camaro is running our heads/cam package with VVT (it's our car actually). That one is full-weight minus the passenger seat, and stock suspension! It ran an 11.17 ET in the 1/4 mile!
If you shoot us a PM, email, or call we can talk about your combo and recommend one for you!
__________________
Old Apr 27, 2011 | 06:25 PM
1BADMC's Avatar
LOL! I am just getting started and thought i should start collecting parts. I dont even know what the engine will be going into yet. I will definitely contact you when Im raedy for a cam.
Old Apr 28, 2011 | 09:26 AM
Sounds good!
__________________
Old Apr 28, 2011 | 08:01 PM
scherp69's Avatar
Matt....I sent you a pm about VVT. Look forward to hearing your suggestions.
Old Apr 29, 2011 | 10:12 AM
Working on that one now!
__________________
