are regular ls2 pistons the same as 402 pistons
Old May 13, 2011 | 07:20 PM
transam8410's Avatar
Default are regular ls2 pistons the same as 402 pistons
hey guys I bought a set of forged pistons and rods for the stock stock of an lq9 but im currently thinking of switching to a stroker setup, my qeustion is.. can I use the pistons I bought for the stock stroke or are they different for the stroker setup?
Old May 15, 2011 | 02:05 PM
KRAZY K 2000 TA's Avatar
way different
Old May 16, 2011 | 09:52 AM
KCS's Avatar
KCS
Moderator
They're different. If you try to use the stock stroke pistons, you'll end up with the piston almost .200" above the deck, which is no bueno. You need pistons with a shorter compression height in order for them to work with a longer stroke crankshaft.
Old May 16, 2011 | 02:24 PM
Thanks guys I appreciate the info, I was just confirming what I've heard... And what you said is pretty much exactly what I heard... Once again thank you
