Lifter bit the dust...
Old May 21, 2011 | 03:58 PM
05gto60's Avatar
Default Lifter bit the dust...
Ive been chasing around a misfire for a little while (stopped driving the car a long time ago, just didnt have that much time to work on it). anyways, this was the thread I started before.
https://ls1tech.com/forums/generatio...fire-help.html
I eventually went back and compression tested each cylinder again. When I got to cylinder number 4 (the one with the mis) I noticed it built compression on 1 or 2 strokes and then stopped. I released the pressure, tried again, and same thing happened. After some deliberation, the only thing i could think of was a bad lifter.
Turns out I was right, but not like I had hoped. much to my dismay I found that the intake lifter (LS7) had ground the roller down a bit. The cam is out and I have new lifters here (Morel link bars) but will be waiting on a cam and pushrods. Im going to throw the cam back in tomorrow and measure pushrod length on another cylinder and order pushrods the same time as the cam. I am planning on using the same grind on the cam since i dont have access to a dyno or tuner over here.
I think this may have been slowly happening since about a year or so ago. I had a valve spring break and I'm about 90% sure it was on that valve. Since I changed the springs out this is the first problem I've had.
Old May 21, 2011 | 05:11 PM
fuel's Avatar
got any pics of the cam....
Old May 22, 2011 | 01:16 AM
05gto60's Avatar
I didnt take any but still can. Its still out of the motor. The lobe looks a lot like the roller on the bad lifter.
Old May 22, 2011 | 03:32 AM
ringram's Avatar
Bearings might be munched up too. Mine were, similar issue, though my lifter died big time. Stopped spinning and wore flat.
Old May 22, 2011 | 06:38 AM
05gto60's Avatar
Heres a shot of the worn lobe. it looks a lot like the roller part on the lifter.
Old May 22, 2011 | 06:42 AM
05gto60's Avatar
Ill try and check them out but (hopefully) there wont be any damage. this roller was still turning, just not in a circle.
Old May 22, 2011 | 11:30 AM
briancb1's Avatar
You can bet the bearings have wear. With the spring pressures we run with these cams, it's part of it.
Old May 22, 2011 | 11:57 AM
05gto60's Avatar
Id need to look at the exact numbers, but the motor only has about 12K-15K on it. It was built the begining of 09 and had been down waiting for a transmission for a while. Replacing the cam bearings over here in Italy is not an option though.
