Ls3/416 running issues need help!
Old May 23, 2011 | 10:56 AM
racerfox's Avatar
Default Ls3/416 running issues need help!
Ok guys i have a 99 z28 that i had a LS3 put in motor build is a ls3 block with WCC Eddelbrock 245 heads in a 72cc with a 243/247/623/623 on a 112 lsa
intake is a ls6 with 36lb injectors tsp 17/8 headers. Ok so here is the issue the car acts like it has a dead cylinder it only made 410 rwhp...We checked the data log it shows bank 2 slightly leaner then bank one.. We changed coil packs no change changed plug wires no changed. We used a reluctor wheel tool and it checks out... The car idles fine and drives ok but is sputters in lower rpm and im about 70 rwhp short of where i should be and im kinda stumped it still pulls hard and i have to use it for LA invasion does any one have any ideas i could try? Also the tune is spot on so its not the tune.
Old May 23, 2011 | 12:14 PM
butler's Avatar
2 things. Your intake is WAY to small and run a compression check to see if you have a bad cylinder. Oh one other thing. Is the cam installed correctly?
Old May 23, 2011 | 02:25 PM
racerfox's Avatar
yes and when you work for uncle sam your kinda stuck on how much you make and a fast 102 is not my concern right now a ls6 will work for now
compression is good btw and so is the cam
Old May 23, 2011 | 04:00 PM
litle88's Avatar
Check your ignition system. Make sure all coils are working, what spark plugs and what gap are you using?
Old May 23, 2011 | 04:06 PM
topfig1's Avatar
intake leaks?
Old May 23, 2011 | 04:26 PM
racerfox's Avatar
swapped the complete coil pack off a other car no diff
Old May 23, 2011 | 10:28 PM
litle88's Avatar
Mafs? Swap that.
Old May 24, 2011 | 08:42 AM
racerfox's Avatar
speed density tune
Old May 24, 2011 | 11:36 PM
RPOWU8's Avatar
Double check that you don't have too much lifter preload. If the pushrods are too long it can hold the valves open a bit. I like to have zero lash plus 1/2 turn. Different lifters need different preload though.
Just a thought
DJ
Old May 24, 2011 | 11:40 PM
racerfox's Avatar
thanks every one i think we found it dirty injectors might be the culprit
Old May 27, 2011 | 03:07 PM
SIK02SS's Avatar
those 36lbs injectors might not be enough in the top end..both my fuel pump and injectors were maxed out on initial tuning of my 416. i now have 50lb/hr injectors and a racetronix fuel pump with wire kit..but haven't gone back for re-tune (injectors obviously not installed yet)
Old May 27, 2011 | 04:09 PM
KFZ)^'s Avatar
I would check injector duty cycle at WOT at high rpms, like SIK02SS said and while you're at it, look into the tune one more time. I would think if it had a dead cylinder you guys would know for sure. Just seems like you need to iron out the wrinkles with that combination.
EDIT: You said "the data log it shows bank 2 slightly leaner then bank one." What did the AFR's look like? What fuel are you using? Can you get us that datalog and dyno sheet?
Old May 27, 2011 | 07:29 PM
litle88's Avatar
Good tO hear!
Keep me posted!
Old May 28, 2011 | 02:48 AM
DietCoke's Avatar
Intake is costing you 30+ horsepower. Might not be all of your problem, but it wont feed those heads, or 416 inches worth a crap.
