Just received my 408
Old May 28, 2011 | 09:03 AM
butler's Avatar
Default Just received my 408
11.0 compression 236/248 .617 EPS cam ls6 ported heads turbo 400 with 4000 stall moser 9" 3.89 gears. Looking to run 10.0's on motor.
Old May 28, 2011 | 10:14 AM
Jimbo1367's Avatar
what vendor?
Old May 28, 2011 | 10:44 AM
butler's Avatar
Local company MC racing in Merriam, Ks. They have been in business for many years. They do a lot of procharger stuff, turbos and such. Wiseco pistons eagle crank and rods.
Old May 28, 2011 | 01:18 PM
Samer's Avatar
Nice, what heads are you going for? what chamber size? intake?
And what is your race weight?
Old May 28, 2011 | 04:19 PM
butler's Avatar
Ported ls6 heads stock chambers vic jr carbed 2975 raceweight. 91 mustang hatchback.
Old May 28, 2011 | 06:26 PM
Samer's Avatar
With a race weight that low, you shouldn't have a problem hitting 10.0's with good suspension.
AJE k-member? Kooks or Dynatic 1 7/8" headers?
Old May 28, 2011 | 06:41 PM
butler's Avatar
Yep. dynatech. Going to paint the car atomic orange. Truly a half breed.
Old May 29, 2011 | 03:19 AM
Samer's Avatar
Congratulations for the great setup and I hope you reach your targeted ET.
I'm currently building a similar setup on a 1992 Mustang but with a 383ci stroked LS1 and AFR heads.
I hope to complete it within the next two months
Old May 29, 2011 | 06:42 AM
butler's Avatar
Very similar to the previous setup I had. 383 afr 225 heads. I went to the track made two runs. No traction whatsoever as it was at the beginning of the year. 10.6 @ 129. 1.70 60' instead of 1.41's like it used to run from last year.
Old May 29, 2011 | 07:32 AM
Samer's Avatar
I have the new AFR 215 and I'm shooting for 10.9 NA and 9.9 with 200 shot
You achieved good results with your old setup. what was your engine compression? trans? stall? cam?
Old May 29, 2011 | 10:18 AM
butler's Avatar
11.3 compression. turbo 400 5000 stall pacesetter 1 3/4. moser 9" 4.11 gears 3200 raceweight in my 99 camaro.
Old May 29, 2011 | 03:38 PM
Samer's Avatar
That was helpful. Thanks !!
Old May 30, 2011 | 06:32 PM
butler's Avatar
Getting closer.
Old May 31, 2011 | 03:35 PM
ryant13's Avatar
Looks good. Where do you run at?
Old May 31, 2011 | 04:25 PM
butler's Avatar
Kcir in Kansas City, Mo. There are quite a few of these builds going on in the area along with the addition of turbos.
