oil priming new crate ls3 engine
http://store.gmperformanceparts.com/...-12368084--%3E
edit: Or hook it to the oil pressure sending unit hole.
so basically what i just said. lol
ive always packed the pump with vasaline before starting. of course, these were new motors with plenty of assembly lube on all the bearings. i could never get any oil pressure just cranking it.
I've seen a few people use a old fire extinguisher too. Same principle.
Depending on how long it sits between starts, you are basically "priming" the oil system every time you start the car, and absolutely doing it, every time you change the oil.....
http://www.youtube.com/watch?v=tOYLl...layer_embedded
OK, if I pump oil via oil pressure sender above oil filter, is it possible to view comming oil via oil filling cap on top of engine?
Something like this scenario:
http://www.dsmtuners.com/forums/arti...installed.html
