ls2 into fbody......parts interchangibility
ok, out of the following list, which parts can i use from my 98 ls1 on an ls2 block with the part number 12568952..all parts from a 98 ls1
-cam position sensor
-lifter trays
-valve covers
-rocker arms
-coil packs
-map sensor
-dipstick
-oilpan
-oil pickup
also...how much power can a stock ls2 crank handle
-lifter trays
-valve covers
-rocker arms
-coil packs
-map sensor
-dipstick
-oilpan
-oil pickup
cam position sensor= different on LS2, it in the front cover
-lifter trays=I would buy new
-valve covers=identical
-rocker arms=-the same
-coil packs=will work
-map sensor=will be the same
-dipstick=same
-oilpan=same
-oil pickup=same
you also need to relocate the knock sensors when going to an LS2. Plenty of articles on the swap if you search.
-dipstick=same
-oilpan=same
-oil pickup=same
