Input on heads/cam for TSP 421 cu in.
Not too many hit 600rwhp NA without very high compression and a monster cam. But TFS 235s would be my choice. They consisently make 540-550rwhp. I havent seen any other head as consisnt as the TFS 235s.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Have switched to a 102/102 and am working on a SD tune. If you are able to tune your own car then I would go SD with the 90/90 to see the results. If it doesn't work out you can always sell the 90/90 and move up to a ported 102.
The car was dynoed with the steel driveshaft through the 9" rear. All accessories attached.
So I say go 102 and don't look back.
Sounds like you got a winner!
For the 416, also look at WCCH L92 heads or MAST LS3 offerings. More money again but better excellent reputation and flow numbers. Watch flow numbers from suppliers - not everyone uses the same bore size and this can skew the values.
