Lunati cam 227/238 583 600 112
Hi about to order this cam for a LS3 , daily driver, Anyone used or heard this cam?
Im hoping it sounds tough. Its a voodoo lobe grind from there catoloque, seems agood compromise between mild and big
Thanks
Thanks
It should be alright. I believe these were some of the last cams done by none other than Ultra Dyne's Harold himself. One of thee top cam guys of all time in the US.
Darin Morgan suggested a 231/243 @.050 on a 113 with LSL lobes from comp for a 6.0L with LS3 heads for my 06 GTO.
Look at the cam cards ICL, that will tell you if it has been ground with an advance.
Just because it's not "popular" doesn't mean it's not a well designed product. People on the boards typically buy what everyone else has here.... Which is sponsor pushed parts. I wouldn't hesitate to try that cam, but money doesn't grow on trees so I'll wait for your results lol.
This Lunati is under 600 LIFT so should be less harsh on the valvetrain. Im just uncertain how the Lunati willsound
