Cloyes Timing Set ? and LS2 Damper ?
Old Aug 10, 2011 | 04:08 PM
bluehawk2's Avatar
Default Cloyes Timing Set ? and LS2 Damper ?
I am looking at the Cloyes Hex-A-Just timing sets and I want to make sure I get the best chain on there...... The part number that I am looking at is 9-3158AZ. Is this the set with the C5R chain?
Also Cloyes list the 9-5491 chain damper.....Is this what i need? I have a ls2 block. I have seen 12588670 ls2 damper before. What is the difference in that and what cloyes has?
thanks
Old Aug 10, 2011 | 04:28 PM
Darkman's Avatar
http://www.cloyes.com/Portals/10/Ima...%20GM%20LS.pdf
Old Aug 10, 2011 | 06:41 PM
bluehawk2's Avatar
Yes, Yes that is correct lol that is where I looked also. My questions are what is the difference in the cloyes damper and the ls2 12588670? The cloyes damper 9-5491 lookes like an older ls1 damper.
Also, what is the z chain? is it a c5r chain?
Old Aug 10, 2011 | 09:52 PM
Darkman's Avatar
According to a non-sponsor website that sells Cloyes part number 9-3158AZ it is the "IWIS C5R Extreme Duty True Roller Chain with .250 Diameter Rollers."
This thread has some info on LS dampners-
https://ls1tech.com/forums/generatio...n-dampner.html
I could not find any comparison of the Cloyes dampner to the old LS1 dampner.
Old Aug 10, 2011 | 11:19 PM
bluehawk2's Avatar
thanks for the link. Looks like the oder style has a different bolt spacing, but I still wonder what the cloyes damper is.
I think im just going to order the damper from the stealership anyway.
Ok, so the chain is the c5r chain
thanks
Old Aug 11, 2011 | 05:56 AM
Darkman's Avatar
thanks
Yes, the IWIS chain is the C5R chain. Buy from a reptutable supplier because there are "counterfeits" on the market.
https://ls1tech.com/forums/generatio...ld-c5-r-2.html
Old Aug 11, 2011 | 02:14 PM
bluehawk2's Avatar
It will come straight from Cloyes through my builder........thanks for the heads up though
