Largest cam on an LS2 w/ported LS3 heads
I really think you need to slow down and think about what you're doing though. Sounds like you're just wanting huge dick-waving dyno numbers. That's the WRONG way to go about modding your car.
My $0.02.
As far as the LS3 heads go - maybe my post was a bit unclear, I was looking to find the "largest" cam possible so I didn't exceed the size and I could rule out a few different cam choices I was thinking about. The car has 243s stock, which is a good base to build on. I'm going to be doing the work myself most likely so I'd like to not have to pull the heads off twice or get into the bottom end just yet (aka flycutting pistons etc).
I'd like 500rwhp as a base....The car will probably hit the dyno only when it's being tuned, Im not out to out dyno other cars or get bragging rights for the highest hp...if I wanted that, I go TT, forge & stroke it and be done w/1000+ at the wheel....I'd rather something I can drive on the streets though. I will do some more digging on this forum before I start asking what should/can I do to get 500rwhp out of an LS2. I know it's fairly easy w/a good tuner, good cam, and an intake w/out getting a new set of heads....again, thanks for all your inputs, this forum is awesome!
I had a stock LS2 bottom end with 243s and a SS-HT cam (228/232 .612/.600 111), and ran that combo for 25,000 miles. Awesome. No dick waving dyno numbers, but I stomped the living **** out of almost everything I faced without a power adder.
I then had valvetrain failure, and decided to just install LS3 heads. I had people here telling me I was a moron...that I would have to fly cut the pistons...and that it would be a dog. Bullshit. I had plenty of PTV clearance, and ran that combination for 40,000+ miles. At that time I was putting down 435/405 (I think), and it was just as easy to drive as stock.
Lost a lifter about 5,000 miles ago, and installed a bigger cam...STILL had plenty of PTV clearance. A lot more power, but never have dynod her with this setup, and probably won't get to. At 120,000 miles of being spun up to redline every day, I think I've lost compression in a cylinder. Hopefully, everything else is still good, and I'll have the short block rebuilt this winter and running the same combo next year. She's a beast and a pleasure to drive.
Good luck on the 500 all motor in a GTO. That's a tall order. At least you got the right intake. I just installed my SVEDE with the new cam...the HP Tuners logs don't lie. That's the GTO intake to have.
500rwhp as a base? Honestly picking a random high single digit number on a dynamic curve is just for bragging purposes.
You will be beat by people who built their cars to have the maximum torque under the curve, not some peaky number (and fat chance you'll do it with ported 243's or LS3's on a 6.0).
Have your cam grinder figure out what would produce the most torque under your operating rpm range. Tune it and it will make what it makes, enjoy a balanced combination.
