Trick Flow Kit vs my LS6 CNC and cam.
About to break down my LS2 and pull the Ls6 heads stage 2 and 231/236 cam for a set of trick flows. Has anyone else used these. I got 475 at the wheels with this cam and heads setup and looking to get more thats why I'm changing. Any info on the trick flows would be great. Actual syno results and what not. Thanks
If you got 475rwhp That's a pretty good number for that sized cam, even with Trickflows. I dont know of alot of cars hitting much more than that with a medium sized cam, or big ones for that matter. I think 427LS7HCI is right about 10hp/10tq at peak ,but probably a fatter curve. It would be a lotta work and $ and no guarantee they will be that much better. What stage 2 LS6 heads are you running now? Sometimes you gotta figure if it ain't broke don't fix it.
too much work for 10 under the curve.. and maybe 5-7 on top..
nah...PROCHARGER!!!
There is another C6 with exact same setup as mine but it has Trickflow 235's on it and I made more.. I'd leave it and save for a blower..
nah...PROCHARGER!!!
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
