Can I put an ls2 rotating assembly in an ly6 block?
.and you could mill to achieve the same compression ratio.
good luck
bpatrol
Yes it is iron BUT boring it to 4.065 will need to be worked on by a shop knowing what they are doing of course. Contact AES they do these alot and they can also get you your stock parts that you need.
also, know of any shops in Al, maybe around Birmingham, that would be competent enough to do this? most of the shops in Montgomery tend to be really old school sbc guys, so I'm not 100% on whether they could do it properly. There's not a whole lot of money down here, so there isn't much market for fast motors, and therefore no real speed shops to speak of
