higher duration or higher lift??
im planning on NA'in the motor but want to hook up No2.. just for late night/strip racing(farely new to lsx motors)... was lookin at a few cams. some with high lift, low duration, or low lift, high durration... found a couple around 609in 612ex dur@.5 238in 245ex.... seein if anyone has some "trial n errors" or "should haves"????
On a stock build a little extra lift is like a few degrees of duration and say 10-20 HP. Thats why many people added 1.6 rockers to there builds on old school small blocks. You can add 1.8 rockers to an Ls1 but its not worth the price of the parts.IMOP.
The cam specs you gave are about right for an LS2. What heads are you running?
its going in a manual 06 gto.. dont know exactly what heads im going to do, pretty much going to base it off the cam i choose... so based of the cam i posted would 1.8 rockers be worth the effort?? i wanna try to put close to 500whp as possible "all NA"...
im used to carbed SBC n all this new lsx EFI computer stuff is confusing but i get the consepy...haha too many options
He will ask you the car, weight, gears, transmission, head flow the works and spec you out a cam based on your needs with what you have. Best $20 spent ever on an engine build!
You can have long duration with low lift.
But if you opt for high lift, then duration needs to increase to smoothen the cam profile, otherwise it would hammer the life out of the valvetrain.
But a low lift, long duration profile could be very smooth, and very easy on the valvetrain. Although it may ( or could have ) have a lot of dwell around the max lift area
24x duration on it, unfortunetly you are going to be limited on lift with a stock ls2 engine with ls3 heads so some extra duration may make up for smaller lift. from what I have read though ls3 heads tend to like lower duration and higher lift my cam has over 640 on the intake side but about 61x on the exaust it is a LG motorsports g6x5 cam I dont know the specs but it put down 505/505 respectivly in a auto GTO with a very restrictive stock intake system. on my car it should make over 550 to the wheeles and still have good street maners.
I would seriously talk to pat G or a actual engine builder for your head and cam setup for your build. cause it will make or break a engine
Yep.
