View Poll Results: Which connecting rod to you prefer for a LSx stroker?
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Why not more 6.200" con rods for LSx strokers?
I've been looking around the web and all of the LSx builds for a 4.00" and 4.100" stroke all call for a 6.125" connecting rod. Why not a 6.200" con rod ?? Are they afraid that the piston used will be too short and not durable??
I did see that Lough Engine Service of Oak Ridge, Missouri and CC Performance Parts of St. Helens, OR does sell 416 ci and 427 ci LS3 stroker builds with the 6.200" rods, but nowhere else that I have seen.
Is it true that the LS3/L92 block has sleeves long enough to accomodate the 4.100" stroker crank without poking the pistons out of zeroed deck where the LQ9/LQ4 block is does not???. So can I build a 427 ci shortblock that can be used for a daily driver with occasional road race and autocross use if use the LS3/L92 block instead of the LQ9/LQ4 iron block??? Can it be as durable as the using the iron block?? Let's say a good 100,000 mile motor?
We just fixed an engine that cracked a couple pistons with .990" CH. The original builder didn't use the correct ring dimension and ring grove dimension for the application.
Another reason why you don't see as many 6.200" rod setups, the rods do cost more, 99/100 people on here are looking for best price, most shops like us are buying rods in volume, 6.125" rods cost little less (due to popularity) and they work perfect for most applications.
I put 6.300's SBC Eagle rods (with the pin end offset unfortunately) in my stock stroke (eagle crank) motor with off the shelf 4.0" stroke pistons from Diamond. If I could do it all over again, I would have just bought the 4" crank and the 6.125 rods. I purchased the rods and pistons when I had a stock crank. Come to find out one of the journals was wiped. Since I already had the rods, I bought a stock stroke eagle to replace it. It runs great, but the extra 40 or so cubes would have been nice.
