Erl 398
Any thoughts on cam specs?
Aaron
thanks
And,
Thanks guys for the valuable input! Ive been really thinking about the bore size and the only problem i have with going with a smaller bore size is that it means if i want to go bigger later i have to send the block out again to be re-sleeved. i hadn't really considered the head gasket issues... i know its no grantee but with ARP studs i should be OK. i will defiantly let whoever specs my cam know about my rod length. i will be using HKE so i should be OK there.
OR, go with a 4.155" bore, sacrifice a little valve shrouding (which I don't see being an issue AT ALL), and having the ability to do a rebore, change the crank to whatever stroke you desire, and not have to worry about buying another resleeved block from ERL in the event something goes wrong with this engine.
As for reboring the engine later, it's not very expensive at all to do, and by doing that would give you a FRESH bore to start out with if/when you do a larger stroke crankshaft.
A perfectly round bore with no wear is gonna help seal the rings better than with a bore that has Some wear. So going smaller now is not necessarily a bad thing.***Smaller Bore now = more material in between the bores for better head gasket sealing, more material to bore later in the event of an engine failure, the ability to use another crank in the event of a failure, and as well as the ability to start fresh with a new bore if/when you do a larger crank...
***Larger Bore = possibly a little more power now, but at the sacrifice that if anything goes wrong, Now you have to buy a new sleeved block, rather than just fix whats wrong with the 1 with a 4.155" bore. So It's more of a luck of the draw kinda thing when going MAX Bore.
IMHO, I always choose peace of mind over All OUT! I would much rather have a second chance (you could say) than go all out and be screwed if something goes wrong.
Either way, I think you'll have a Very strong running engine no matter what you decide. I'm not trying to tell you what to do obviously, I just wanted to give my .02.
and its only availible up to a 4.125" bore according to their new website.
