Piston Shopping
Old Nov 23, 2011 | 12:10 PM
5 Liter Eater's Avatar
Default Piston Shopping
I am looking at putting forged pistons and rods in my LS2 on the cheap. Piston shopping is a bitch! The only place I've found that allows you to puy the specs in and return something is Summit. I want a stock bore (4.000 or 4.001) and stroke (3.622) piston with between a -4 and -12ish dish. I'll be running stock 243 heads which are 65cc. This is going to be a turbo setup but I'm not willing to drastically reduce compression. I want to target 10:1 but no lower than 9.5:1.
Thunder Racing has some -4cc Mahles for $537 that are on the high side compression-wise but would work.
Summit has some Probe pistons (never heard of them) for $507 with either a -16cc dish (too low) or -3cc valve reliefs for $479.
I've pretty much made up my mind on SCAT rods and perhaps upgrade the bolts in them to ARP 2000's.
Old Nov 23, 2011 | 12:14 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
http://www.texas-speed.com/p-730-wis...22-stroke.aspx
There's a -3.2cc flat-top and the 4.000" finish bore is available.
http://www.texas-speed.com/p-734-wis...22-stroke.aspx
There's a -11cc dish with the same 4.000" finish bore available.
Both are setup for the aftermarket 6.125" rod with .927" pin.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 23, 2011 | 02:02 PM
Weisco's would be what I would want if I had my choice so it's good to know they come in a 4.000 bore. A little spendy though. The Mahles are a few hundred less.
Old Nov 23, 2011 | 02:09 PM
When you price a steel top ring set for the Mahle's, you'll spend as much if not a little more than you do on the Wiseco's. Also, the inexpensive Mahle's are 4032 forgings, not 2618. You have to get into the bigger dish pistons to get their 2618's.
__________________
Old Nov 23, 2011 | 11:01 PM
Wiseco's come with steel top rings. Also good to know.
Do you have the compression numbers for both those pistons with a stock 243 head and LS9 gasket? That -11cc might be just what I need. And there's nothing else available in that dish and 4.000 bore.
