Ls3,l92 piston whats the difference?
Old Nov 30, 2011 | 07:36 PM
NOVACRAZY2007's Avatar
Default Ls3,l92 piston whats the difference?
What is the differance with a ls3, l92 piston? Will regular flat tops work with those heads? Are the valve pockets offset or something? Some manufactures have ls3,l92 specific pistons. Why?
Old Dec 10, 2011 | 04:43 AM
rsz288's Avatar
L92's run VVT so the pistons have exhaust valve reliefs. LS3 are flat tops.
Old Dec 10, 2011 | 07:17 AM
SweetS10V8's Avatar
This is correct...
Becasue L92/LS3 heads use a 2.160" valve, which is much larger than the standard 2.000" valve in most cathedral port LS heads. They have to make the valve relief larger knowing its going to be used in conjunction with a very large valve.
Old Dec 10, 2011 | 09:35 PM
Oh4GTO's Avatar
Theres also two valve reliefs per piston which equate to -4cc.
Old Dec 10, 2011 | 09:59 PM
litle88's Avatar
Bingo!
Valve reliefs on both intake and exhaust
Old Dec 12, 2011 | 12:13 AM
Oh4GTO's Avatar
Actually its just for the intake. However they only manufacture one type so each piston has an extra intake valve relief on the opposite side.
Old Mar 14, 2014 | 11:46 AM
jgauspohl's Avatar
Sorry to revive an old thread but if I delete my vvt can I run the oem ls3 flat tops in my L92 with the L92 823 heads? Block and head surfaces are stock and using factory mls ls3 headgaskets. Greatly appreciate any help on this.
Old Mar 15, 2014 | 06:31 PM
Jimbo1367's Avatar
YES. YOU CAN RUN LS3 PISTONS (flattops). Just be curtain to mic the cylinders and pistons. If they check out ok, you might want to have a machine shop cut valve reliefs.
