PTV clearance,
Old Dec 10, 2011 | 02:38 PM
azzkikrcuda's Avatar
Default PTV clearance,
Checking PTV clearance on the motor I am building. I already measured my pushrods and have them set up for .065 to.070 preload. When checking PTV should I use My new pushrods or the adjustable one that is set for zero lash?
Old Dec 11, 2011 | 11:35 PM
I am using the light checking springs on the valves. If I use the regular pushrods the valve would still be open .065 when the cam is on the base circle. Where if I use the adjustable one the valve is closed. None of the threads I have read say anything about which pushrod to use. But I would think the adjustable would be correct.
Old Jan 10, 2012 | 07:11 PM
JPH's Avatar
JPH
Use "checking" springs with intended length pushrods to check your PTV.
