427 build
Old Dec 23, 2011 | 12:17 AM
LS1 TJ's Avatar
Default 427 build
Darton sleeved block. LS2 dry sleeve.4" stroke and 4.125 bore.
Manley rotating assembly.
10.8:1
LS3 heads and LS3 intake. 1.875 long tube headers.
Car is 2900 lbs. 3.50 gears. Built 4L60E. 3200 Yank stall converter.
Local LS builder suggests a cam with Intake 230 and 239 exhaust. .610 on intake and .540 on exhaust.113 lobe center.
Does the .540 seem a bit low?
This car will be a street driver. No power adders.
Would like some opinions.
Old Dec 23, 2011 | 09:17 AM
COPO9560's Avatar
Heads and intake ported or stock? With a 427 porting would provide a good gain for the money.
At 2900 lbs, this should be a lot of fun on the street - what kind of car?
Old Dec 23, 2011 | 09:28 AM
82cetuner's Avatar
dont understand why you didnt go with a ls7 top end since you have the bore for it. would make alot more power
Old Dec 23, 2011 | 09:55 AM
Nowhereman's Avatar
Would be a lot more fun if you ran a blower with compression around 9.5.
Good set of injectors and a roller blower cam.
Now thats a Hell of a Lot of fun.
Old Dec 23, 2011 | 01:28 PM
LS1 TJ's Avatar
67 Nova is the car.
Trying to do somewhat of a budget build. Had the LS3 stuff. Build the bottom end so I don't have to mess with it. Top end stuff can I change or improve as time and cash allows.
My real question was on the cam specs. Haven't bought anything yet just wodering about the .540 on the exhaust lift.
Thanks
Old Dec 23, 2011 | 01:33 PM
LS1 TJ's Avatar
I should of said stock LS3 intake and heads.
Cam wise I was thinking 230I/235E about .610 lift on intake and exhaust. 114 C/L. I know it seems mild but again as I mprove stuff like heads and intake I can move up to a bigger cam.
Old Dec 23, 2011 | 03:50 PM
WKMCD's Avatar
This guy has done a ton of R&D with L92/LS3 heads over a couple of years. From 403 to 427. Stock heads, WCCH Stage 2 and 3 heads. Multiple CR's, cams, etc. etc. etc....
https://ls1tech.com/forums/generatio...b-c-d-e-f.html
