To get 11.0 CR, what mill value required L92 head
LS1 Tech Administrator
No, it's the same as an LS1 head. You just heard wrong.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
I have a stock lq4 with L92's milled to a 64cc chamber. My cam is tsp 233/239 .595/.605 114 LSA and IIRC my ptv was around .120 at TDC. I put the number 1 cylinder on TDC and put a dial indicator on the end of the valve stem, and with a checker spring on the valve pushed the valve down until it hit the piston and read the indicator.
Its a good idea to check between 15* before, and 15* after TDC, on both valves
Now the case I have:
The Compression Ratio (CR) is 10.8
Please correct me if I'm wrong...
Now to get 11.0 : 1
Keeping the item no. 1, 2, 3, 4 the same as above calculation, but changing the item no. 5 from 70cc to 68cc, this will yield the following:
The Compression Ratio (CR) is 11.04
Now to get 11.6 : 1
Keeping the item no. 1, 2, 3, 4 the same as above calculation, but changing the item no. 5 from 70cc to 64cc, this will yield the following:
The Compression Ratio (CR) is 11.6
Now milling the head by a 0.006" is equal to 1cc.
Thus to get 64cc from the 70cc, it require to remove 6cc.
Thus 6cc is equal to 0.036" (0.9144mm) to be removed.
It would be fine to make it 0.0315" (0.8001mm) to make it 11.5 : 1 CR
- Engine Bore: 4.0845"
- Engine Stroke: 3.622"
- Gasket Thickness: 0.051" (data from http://www.fbparts.com/ls_general_charts.htm)
- Gasket Bore: 4.100" (Assuming it is 4.100", since I couldn't find this value)
- L92 Cylinder Head Combustion Chamber volume: 70cc (data from http://www.fbparts.com/ls_general_charts.htm)
- Clearance Volume (Distance between the top of piston cylinder to block deck): -0.007" (Many thank to SAMER for his valuable information he provided, Negative value mean the piston is out of or above the block by 0.007" for stock LS block if the deck is not milled)
- Cylinder Swept Volume: 0.7853982 X Bore X Bore X Stroke = 0.7853982 X 4.0845 X 4.0845 X 3.622 = 47.5 ci
- Clearance Volume: 0.7853982 X Bore X Bore X Deck Height = 0.7853982 X 4.0845 X 4.0845 X -0.007 = -0.0917"
- Piston Compression Volume: Assuming it is 0cc since it is flat piston.
- Head-Gasket Volume: 0.7853982 X Gasket Bore X Gasket Bore X Compressed Gasket Thickness = 0.7853982 X 4.1 X 4.1 X 0.051 = 0.673"
- Chamber Volume: cc's X 0.0610237 = 70 X 0.0610237 = 4.272"
Now to get 11.0 : 1
- Chamber Volume: cc's X 0.0610237 = 68 X 0.0610237 = 4.1496"
Now to get 11.6 : 1
- Chamber Volume: cc's X 0.0610237 = 64 X 0.0610237 = 3.90552"
Those are the correct calculations, but the issue I see is you are using theoretical numbers, ie. piston height and combustion chamber. Before I had the heads milled I would preassemble the motor and check the actual piston height and have the combustion chambers cc'd. I have read L92 chamber volume go all the way from 65 to 70 cc's depending on who you read.
