Need Help!!!
Old Jan 3, 2012 | 12:31 PM
ramirop's Avatar
Default Need Help!!!
Okay guys this been going on since last year so basically i'm stumped and in need of help.
I have an 02 SS, before i did the tune up my car would start stay at about 1000 rpm for a couple of seconds, sputter until shut down. Restart give about 1/4 throttle keeping the rpms up around 1000, would still sputter then the rpms would spike up to 3000 rpms i would release throttle and then shut down. This would happen for about 5-6 min until reaching operating temp. keep in mind ambient temp. is about mid to lower 30's. Again after it reaches operating temp. the car drives just fine until it sits over nite. Did the tune up changed fuel filter, still the same problems occur.
Any insights of what might it be i would gladly appreciate it.
Old Jan 3, 2012 | 12:35 PM
KevinR's Avatar
What all do you have done to the car?
Old Jan 3, 2012 | 02:32 PM
ramirop's Avatar
my car is stock, no mods what's so ever...i don't consider msd wires with ngk plugs as a mod...
Old Jan 3, 2012 | 07:27 PM
KevinR's Avatar
I'm assuming you changed all of the plugs and wires during the tune up? Kinda sounds like it could be a fuel issue. Have you checked the fuel pressure?
Old Jan 3, 2012 | 07:56 PM
ramirop's Avatar
i havent checked the pressure since the car runs like a dream after warm up, its only in the morning esp when the temp outside is in the mid low 30's. the thought has come to mind, just in case it isnt fuel re;ated do you have any other idea what it could be....have you heard of this problem before
Old Jan 4, 2012 | 08:49 AM
KevinR's Avatar
Man it could be a few different things. Maybe fueling, spark, or a computer issue. See if you can pull any codes.
Old Jan 4, 2012 | 09:06 AM
ramirop's Avatar
one code that keeps on coming up is Bank 2 catalytic converter, i have cleared the code but this problem started before i started getting that code. I plan on checking the psi on the fuel pump what is a typical good reading anywhere between 50 to 60 psi...????
Old Jan 4, 2012 | 09:12 AM
KevinR's Avatar
55-60. If you have a bad catalytic converter, then that may be what your problem is.
 Michael S. Palmer
Old Jan 4, 2012 | 09:24 AM
ramirop's Avatar
thanks bro, i'll check the psi today and see if i can get the converter replaced...i'll holla back if any progress was made....
Old Jan 4, 2012 | 09:32 AM
lt1pwr1's Avatar
Sounds like maybe a bad coolant temp sensor that is dumping fuel on start up. If you can get a reading on that and see if it is pegged way cold (like -40) then that may be your issue.
One virtually free thing you can do is to clean your throttle body and the TB blade ends where they would touch the throttle body. These engines are notorious for getting carbon build up causing a bad idle.
Old Jan 4, 2012 | 11:24 AM
sicksspeed's Avatar
I think it sounds like a possible vacuum leak. With scanner look at fuel trim. See if is adding fuel.would be a high number though.
Old Jan 8, 2012 | 12:06 AM
ramirop's Avatar
i have taken off the throttle body and cleaned it all out even the iac...i haven't checked the coolant temp sensor, that didn't come to mind i will try that to see if that can be a possible problem thanks for the info.
Old Jan 8, 2012 | 01:16 AM
wildcamaro's Avatar
i dont know man the way you make it sound its like theft is killing it...i would def check fuel pressure since that easy enough...is the chip in your key loose? i know when mine was it would "theft stall" on me...
Old Jan 10, 2012 | 08:55 AM
ramirop's Avatar
i had the "theft" bypass...i disconnected the air mass flow sensor should the engine bogg or there shouldn't be any hesitation.
