my ls3 h/c combo added twin turbo on my ls2 c6 z51 vette build list
#142
Sat and sunday both rained so I haven't got to it yet.. I did put the car on jack and figured out how I'm doing it.. I have to take the radiator out again and move the power steering cooler.. I'm sure glad I don't have to remove that power steering bracket again! While I'm at it I figure I'll swap out the shocks as well.. Here's a quick video of the borla system and then I took it off and just put the 3in down pipes back on...
With the borla system... just started it cold.
http://s912.photobucket.com/albums/a...t=cd260b05.mp4
3in dumps cold start
http://s912.photobucket.com/albums/a...t=4ddd075f.mp4
#148
http://www.youtube.com/watch?v=lwfaO...e_gdata_player
Done...will be tuning hopefully next week sometime
#149
Holy crap you got it done fast... I'm sure you will be well pleased with the ls3 set up. Your car is going to be 100% done soon... and mine still need a little more work...
#151
sweet I would like to hear some numbers.. SOP is wear it's at though. What intake did you go with.. any porting? I was putting on my suspension and I managed to snap a bolt in half...
#153
Finished installing the shocks... got the car prept to take the radiator out... I was looking at the clutch line and rpm didn't even wrap it with protective heat wrap. The clutch line is about 1 inch from the header collector point. Explains why after a nice solid run I lost my clutch pressure.. So I went to auto zone and bough some of the heat protector tubing and fixed there issue... I can't belive I paid them 550$ for such a crap job... the front 02 sensors are loose... so I tighten them... And I noticed another issue.. The passanger axle boot is leaking.. I paid them 175$ for them to replace it.. I notcied it when I got the car back from there but I thought it was just from them changing it.. here 2 weeks later and looks like fresh leaking... I will be calling them tommorow about this..
![](http://i912.photobucket.com/albums/ac326/riapooh18/a4e8451a.jpg)
#154
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
