help please
Old Jan 11, 2012 | 05:35 PM
Andy fortner's Avatar
Default help please
i got a 6.0 370ci it has tsp ls6 head all arp bolt brand new cometic mls head gaskets arp head studs motor runs good but its building pressure in the radiator the car is not running hot i mean u can let it set for 2 or 3 days and go out ther crank the car and in a matter of seconds it will blow hoses no whater in oil so im lost done did all i no to do other than get some more haeds and try that can yall help thanks
Old Jan 11, 2012 | 05:59 PM
JPH's Avatar
JPH
How tight did you torque your heads stud nuts to? Any spray sealant on the gaskets did you use? Block/head finishes look good?
Old Jan 11, 2012 | 06:09 PM
i tighting them to arp spec i think like 80 or 85 yes i used Copper SPRAY the block and head looks good going to get head checked for sure tho in the moring
Old Jan 11, 2012 | 06:17 PM
JPH's Avatar
JPH
Looks like you did it correct. If the head checks out ok, inspect the block. Otherwise I would order new set of gaskets or try and clean/reuse your current cometics and prep them a tad different next time. Was the gasket bore larger then the chamber of the cylinder head?
Old Jan 11, 2012 | 06:18 PM
no it was a 4.30 bore gasket same as motor
Old Jan 11, 2012 | 06:24 PM
JPH's Avatar
JPH
4.300? Do you mean 4.030? What heads? Rule of thumb is gasket bore should be .030 more then what the engine bore is. 4.030 bore +.030=4.060
Old Jan 11, 2012 | 06:33 PM
ya 4.030 and the gasket are 4.060 my bad
Old Jan 11, 2012 | 07:41 PM
JPH's Avatar
JPH
That is checks out good to.
Old Jan 12, 2012 | 11:23 PM
well took heads to shop to day and pressure checked them they was good head gasket was good checked top of block it looked good so i put it all back togather well got it back running well no luck same thing well i took belt off to see if it may have something to do with water pump wit still same thing so next i took Thermostat out and put belt back on well it help some but still builing pressure in Coolant
Old Jan 13, 2012 | 10:31 AM
JPH's Avatar
JPH
Darn. What kind of boost psi are your running again?
Old Jan 13, 2012 | 12:51 PM
10 pis but it dose it when its at idle only thing i can come up with is the block is cracked some where but makes no cents cause ther is no water in oil
Old Jan 13, 2012 | 12:56 PM
87silverbullet's Avatar
The cylinder wall could have a slight crack in it. A crack in a cylinder wall would not show water in the oil but it will pressurize a cooling system.
Old Jan 13, 2012 | 04:28 PM
JPH's Avatar
JPH
check between #3/5 and #5/7 cylinders for any sides of cracks.
Old Jan 13, 2012 | 04:38 PM
i did but did not see anything well i got a coolant pressure tester i got 26 pis on it to see if i can find any cracks or get some cule of whats going on but ya i kinda thinking somthing wrong with block but i have never seen a lq9 or 4 block craked but its my kinda of luck i will have one
Old Jan 13, 2012 | 09:16 PM
26 psi is nothing compared to the cylinder pressure of an engine.
You might have to pull it and magnaflux the block.
Old Jan 13, 2012 | 09:40 PM
wildcamaro's Avatar
I know this is a dumb question, but do you have a line from coolant steam plugs on head to radiator or a line from water pump to rad? That could be you over pressure coolant system if not, figured I'd throw it Out there
Old Jan 13, 2012 | 10:42 PM
JPH's Avatar
JPH
Good idea. It's gotta be something simple I would say. (I hope)
Old Jan 13, 2012 | 11:02 PM
wildcamaro's Avatar
Old Jan 14, 2012 | 10:16 AM
yes i have a hose from the head to the radiator
Old Jan 14, 2012 | 11:18 AM
wildcamaro's Avatar
is it a line from the front coolant bypass crossover? or do you have it running straight from head?
Also i have seen excessive coolant pressure caused by a bad radiator cap...i know its simple but it DOES happen...
I always approach things with the KISS method, and then if that dont work i got to the more in depth reasons it could be acting up...
Good luck man, hope you get her fixed...
