Cams with -1 overlap?
Old Feb 6, 2012 | 10:20 PM
  #61
speedtigger's Avatar
Old School Heavy
Originally Posted by LTX355
Shouldn't be picking lsa on cam just for sound.
Hmmmm. I think his cam selection is about what he wants. If he is willing to give up the perfect ideal cam for that last ounce of peak power for a cool sounding idle, who are we to tell him he "shouldn't".
Old Feb 7, 2012 | 06:21 AM
  #62
litle88's Avatar
+1 he knows what he wants ie sound and power. Stab her with that can and see how she squeals. Keep us updated.
Old Feb 7, 2012 | 07:00 AM
  #63
LTX355's Avatar
not trying to second guess him but who knows lunati may have tried it with different lsas and decided on what they did for a reason. Im also interested in the results if he does it.
this cam is not far from what has been proven before like the 218/230 grind. Id like to see it compared to a plain 224 cam. The old 224 cam has great results even in an ls3
Old Feb 7, 2012 | 07:40 AM
  #64
sweetC5's Avatar
How much top would I be giving up by going from 112 to 110! I figured that wouldnt even be noticable, kinda figured lunati set it 112 just for the sake a of smoother idle because its NOT a big cam.
Old Feb 7, 2012 | 08:09 AM
  #65
litle88's Avatar
112 is still pretty choppy
Old Feb 7, 2012 | 08:18 AM
  #66
LTX355's Avatar
well if your doing the 110 i wouldnt let them grind it with any advance in it because if you do advance it 4 degrees you looking at a 34.5 intake valve closing point which brings the power band down. Cant really say how much but it does. Maybe one of the cam techs can give you a generalization with their software programs.
Old Feb 7, 2012 | 08:56 AM
  #67
sweetC5's Avatar
Ya its a 112/108 but its only 217/228 duration so its about -1 overlap. If I do 110 it will be around +1-2 overlap.. so if they do it 110 it would would have +2 advance inseted of 4 also.
Old Feb 11, 2012 | 10:10 AM
  #68
ronbros's Avatar
i'v read thru this topic,and it seems there is a missed theory on negative overlap cam events!
most if not all short overlap cams(including negative) are designed for TURBO engines!
when most turbos will produce high exhaust manifold pressure,higher than intake pressure,
overlap with both valves open , exhaust will flow back into inlet port and really slow down inlet flow, as well as disrupt pulse flow.
so simply close the exhaust valve before TDC, and dont open inlet until ATDC, (and use the hi-pressure of the turbo to force more air in cylinder,simple right!!!)
and it will raise mid-range TORQUE a lot, some time close to 50%.
anyway thats my take on it, and like any race project all depends on overall setup!
Old Feb 11, 2012 | 10:27 AM
  #69
Old School Heavy
Actually no. All kinds of camshafts including the factory piece have negative overlap at .050". As for aftermarket performance camshafts, sometimes people just want a smooth idle and low emissions.
Old Feb 11, 2012 | 09:27 PM
  #70
sweetC5's Avatar
I was worried about that, I might just stick with the 112 but I will talk with them soon. Looking to order around the beginning of March, I wonder if I did 111 if that would even be anything you would notice other then a bit more lope. That would add 2 degree more over lap, but might not do much to the power band. I will definetly ask when I call to order. Stupid cam, I cant wait till its in so I can stop thinking about it Been busting my *** working and just dont have the time to even do it, but March is dead line... time for something nice for me beside ******* work!
Old Feb 11, 2012 | 11:16 PM
  #71
litle88's Avatar
112 bud would be my choice. It's pretty damn choppy. Wish I had a video of my hot am wish was 112 too and that wasn't even a true dual like you 5th Gen guys. I looked on fquick and it was taken down sorry I'll try looking for it later but it was pretty choppy.
Old Dec 15, 2012 | 11:04 PM
  #72
JakeFusion's Avatar
Super Hulk Smash
I know this is a bit old but I was just reading through... wondering what the OP ending up doing?
Corvette Forum is an interesting place to look at LS3 cams. One of the most popular there is a 230/234 114+2. It has 4 degrees of overlap and drives nice and hits close to 500rwhp on stock LS3 heads. Torque is usually in the 460 range. Say what you will about huge splits, but reversion and additional overlap just kills the drivability without substantially increasing performance from what most have seen.
As PatG said in this thread, the LS3 has a good exhaust port. Just the intake is so good, you can rely on less cam there to make more power. Or, as show in the 230/234 cam, reduce the exhaust duration so you can add more intake to create power without getting into overlap/reversion issues. I think Spin over on CF ran a 234/228 reverse split and made huge power as well. It's all about feeding the intake of those heads.
