TSP / PRC 265cc LS7 Heads for min 4.060 bore
Old 07-13-2012, 12:39 AM
DietCoke's Avatar
Originally Posted by lt1773
any dyno # yet ?
Thought I posted this already
Made 602 STD, 591 SAE
Old 07-16-2012, 01:54 PM
lt1773's Avatar
Wow very strong .now you can beat the LS7 lol
Old 07-16-2012, 04:34 PM
c5z16z's Avatar
so can you run these heads on a 4.065 bore LQ9 iron block?
Old 07-16-2012, 04:56 PM
87silverbullet's Avatar
^^^^Yes you can.
Old 08-03-2012, 06:39 PM
lt1773's Avatar
i justordered same heads and im waiting them badly
Old 08-03-2012, 10:45 PM
c5z16z's Avatar
what vehicle did these go in too?
and what camshaft ?
Old 08-03-2012, 10:59 PM
Fbodyjunkie06's Avatar
Wow impressive for sure.
Old 08-04-2012, 01:01 PM
DietCoke's Avatar
and what camshaft ?
251/259 .670 lift, 113+3
It's a 2011 camaro with a 4L80. No doubt you'd see better numbers on an Fbody or corvette, especially with a manual trans
Old 08-04-2012, 01:34 PM
Oh4GTO's Avatar
I really want to see these on an a stock LS3.
Old 08-04-2012, 06:33 PM
If only they allowed LS7 heads in RS275....
Old 08-04-2012, 06:47 PM
lt1773's Avatar
Do you think it will make more/better # with Single plan LS7 intake with 4500 tb than fast 102 intake ?
Old 08-04-2012, 06:56 PM
  #32
Jimbo1367's Avatar
Maybe
Old 08-04-2012, 07:17 PM
  #33
Oh4GTO's Avatar
Still seems pretty low considering what I make wit stock parts and 5 psi. I am an M6 but GTO's aren't dyno queens either. The 80 can't be robbing that much power.
Old 08-04-2012, 07:31 PM
  #34
DietCoke's Avatar
100% yes. It would probably make 650 with a victor. A single plane with a 4150tb is complicated with drive-by-wire (remember, this is a 2011 camaro). I have a rudimentary solution in place, but it still needs refinement.
Old 08-04-2012, 07:33 PM
  #35
DietCoke's Avatar
5 psi on a 450hp motor is worth ~150hp to the tire. You tell me.
Old 08-04-2012, 08:06 PM
  #36
Oh4GTO's Avatar
Never mind, I just realized you are all motor. In that case nicely done.
Old 08-05-2012, 12:48 PM
  #37
lt1773's Avatar
Just ordered same heads and cant wait till they arrive
Old 08-05-2012, 01:53 PM
  #38
Jimbo1367's Avatar
what engine/setup are you running? Any dyno and strip #s to follow?
Old 08-05-2012, 04:04 PM
  #39
lt1773's Avatar
ls3 416cu
Garrett gt 91
PRC ls7 small bore heads
GMPP single intake ls7
Th400 ,PTC converter
Old 08-05-2012, 05:15 PM
  #40
Jimbo1367's Avatar
ls3 416cu
Garrett gt 91PRC ls7 small bore heads
This woulda been a beast NA. Now its just stupid. LOL. I will be looking for your build thread so I can subcribe to it.
Quick Reply: TSP / PRC 265cc LS7 Heads for min 4.060 bore
