Cammed LS7
Old Mar 5, 2012 | 11:33 PM
yonerhottlt1's Avatar
Default Cammed LS7
A good buddy of mines and fellow car club member has a 2007 Ron Fellows edition C6 Z06. Motor has only 4k miles on it. We just picked up a QM600 cam for it and plan to install it with a few bolt ons and a good tune of course. Exact specs according to the cam card 242/254 .657/.650 113 LSA. Car already has a calloway CAI on it and runs pretty damn strong as is. Plans are to add 2" primary LT's, and supporting valvetrain mods (hardened pushrods, upgraded valvesprings, trunion roller rocker upgrade etc.) Looking for advice on what parts to go with on the valvetrain so he can get them on order. Also, what should he be expecting power wise?! Any other suggestions?!
Old Mar 6, 2012 | 07:07 AM
ramairws6's Avatar
Can i ask why you went with the QM600? That cam is waaaay behind the times! I had that thing in my 427 back in 2006 and it wasn't a great cam to be honest with you. You will be dissappointed in the torque department. Not hatin' just trying to warn you.....
Old Mar 6, 2012 | 08:03 AM
good2go's Avatar
I'm running the QM600, had it in since 2007. It does have less torque than the more modern cams. It also has low rpm/low throttle bucking. With stock heads I got 540/480 SAE HP/TORQUE.
Old Mar 6, 2012 | 08:27 AM
ramairws6's Avatar
Ya, that too. Took a real good tune and even then the drivability was horse **** at best plus the low tork. It was a great cam in the begining of all the LS7 cammed madness but if you threw a different cam in that thing you would be dumbfounded at how much your missing out
Old Mar 6, 2012 | 08:28 AM
ramairws6's Avatar
I'm going on my 8th cam test and out of all of them the QM600 was the second from the last that i would recommend. That should say alot....
Old Mar 6, 2012 | 11:42 AM
sandragnx's Avatar
What cam would be in your top three?
Old Mar 6, 2012 | 03:10 PM
When I looked on the website the specs were a lil bit different from what it says on the custom cam card so I'm a lil bit confused as far as that goes. So you guys would suggest maybe selling this cam and getting something better?! I thought this would be a good choice from the specs but the reason for me making this thread was to get suggestions from people with experience so thanks for pointing us in the right direction.
Old Mar 6, 2012 | 04:02 PM
Anybody running the lingenfelter GT-21 LS7 cam?!
Old Mar 6, 2012 | 04:07 PM
Ragin Racin punisher?!
Old Mar 7, 2012 | 12:05 AM
delphigto's Avatar
Check on the corvette forum more z06 guys over there.
Old Mar 7, 2012 | 01:08 AM
Found some useful info there. There are definitely better grinds available in todays market. The punisher from Ragin Racin looks very promising and seems more along the lines for what we're looking for. Any other opinions/suggestions?!
Specs:
236/256 .660/.660 111LSA
Old Mar 7, 2012 | 06:50 AM
ramairws6's Avatar
Carlos likes to tease so those specs he puts out anywhere are ficticious. The dude keeps his stuff secret and there is a reason for that let me tell ya.
Old Mar 7, 2012 | 06:52 AM
ramairws6's Avatar
Specs:
I'll help you out a little here and just say to use the LSL lobe from Comp and you'll be happy...
Old Mar 7, 2012 | 06:55 AM
ramairws6's Avatar
Specs:
Some of Ragin's grinds are pretty good. I had the Striker for awhile and it was an animal at the track! I see they have a Striker 2 now but not sure if anyone has tried it yet??
Old Mar 8, 2012 | 01:38 AM
Won't be seeing too much track time which is why we've decided to take a step down and use the punisher. And with that cam he should still have plenty of room to grow. Anybody know what kinda lobes the RR cams are on?!
Old Mar 8, 2012 | 07:17 AM
MGGLS1's Avatar
I went through this a couple of years ago. I originally had a custom spec cam from cam motion speced from LME...243/253 113+3 .630 lift. It was a dog down low with only 535 rwhp and drivability not that great.
Then I went to the Katech Torquer with the 110 lsa, and it totally transformed the car. The torque down low was amazing and it put down almost 540rwhp. The driveability was much better, and I would use this over and over again in any LS7 based setup. I know the specs look odd, but this damn thing really works!!!
Old Mar 11, 2012 | 07:41 AM
nascarnate326's Avatar
One of my good friends has that cam.
His idle is to die for
http://youtu.be/0hDSp0KAFHo
http://youtu.be/PUTYDySmD6M
Old Mar 16, 2012 | 12:22 AM
Corvee's Avatar
What other mods to the engine? Manifold, TB, heads?
Old Mar 16, 2012 | 08:51 AM
MGGLS1's Avatar
Ported stock intake and TB...stock heads and 1 7/8 primaries to 3.5 collector.
T56 with 3:70 Ford 9 inch rear.
Katech also makes the LS7 Torquer on a 116 LSA for a smoother idle, just makes a little less of both power and torque.
Old Mar 16, 2012 | 07:06 PM
Any numbers on that beast nascarnate326...?!
