Best company for LSX 454?
The price range is VERY different. If you want a fully forged custom build it is almost double the GMPP long block, which you can get for around 9200 from city.
Repeat: it will depend on your power goals and budget, which needs to be the first thing you figure out because it will drive everything else
But you should be able to have an lsx block built engine built for around the price of the gmpp one.
If you are on a limited budget, money goes a lot further on 4 inch bore iron block engines. You can get a long block 408/418 for way less than a 454. Yes it won't make over 600 rwhp in NA mode but add $1K for a small N2o system and you are over the 454 anyway.
The 4.125 inch and up engines are great but they are far from budget friendly. You will likely make more power with a properly assembled long block 408 than the 454 with LS1 heads.
If you are dead set on large cubes and want to reuse as much as possible, consider sending your existing block to ERL. For less than $7K the Superdeck treatment can get you a 454 and your parts will fit back on. At a minimum you should consider swapping stock LS3 type heads for your LS1's.
