Cam choice? EPS vs. TSP
Going with a slight variant of the 230/246...230/242 on a 113.
Sticking with 1.7 stock rockers. He said he has this cam in cam only 2010 camaro's making 480 at the ground.
So that is settled. Can't wait to start getting it together.
Let me tell you of what Geoff does in his spare time. Now most of you are probably like me and have an issue of GM hihg tech mag or some other magazine in your bathroom so you can do your research
. I was at Geoff's shop one day, getting a friend of mine's car tuned and I told Geoff I was going to the bathroom. He tells me check out the book in the bathroom. I get in there and there is a book on the back of the toilet that is titled "Internal Combustion Engine Intake and Exhaust Fluid Dynamics". I'm like damn! This dude reads this kind of **** when he *****! I couldn't understand half the **** in the book. So this tells you the kind of stuff Geoff thinks about even in his off time.
By the way he is most likely to tell you to use the Patriot Gold .660 springs. Thunder uses them alot on their cams. They are a very good spring. I would say something like LS7 lifters for your combo.
will stock lq4 valve covers not clear the stock ls3 rockers?! I thought they did...
EPS lobes are VERY nice there is NO chatter at all on my EPS cammed L92.
http://camaro5.com/forums/showpost.p...3&postcount=65
I really hope all my problems with my truck didn't come from my buddies cavalier I jumped with it recently...he hit a pole...so I'm worried I might hit one too...
Last weekend at the track, a friend of mine asked why I didn't attend much of the our local 5th gen meets, and my reply was I didn't have much in common with the "halo light and sticker crowd".
...but to stay on track with the OP, this EPS 230/246 grind has been on my mind for awhile. Looking like I might have to replace a collapsed lifter, so if I'm going to remove the heads, well, I might as well do a few other changes, LOL
Thats just cuz they're all so baked they caught on that we were stealing their tunes with booster cables but little do they know we can beam them off the radio antenna
