Cam choice? EPS vs. TSP
Old Apr 20, 2012 | 07:26 AM
bww3588's Avatar
Default Cam choice? EPS vs. TSP
Need to get a cam for my engine her before too long...been recommended the 231/236 cam from TSP. But I have been looking around as well at other cams.
370 with LS3 top end. stock heads, and intake with a 92mm TB. about 11:1 compression with full dual exhaust, FTP 104 lid, 100MM MAF...etc
came across this EPS cam.... 230/246 .600/.609 113
any opinions? would the EPS cam be a better choice?
from what I have been reading, more split, looser LSA is not needed on LS3 style heads like everyone thinks...so I'm leaning toward the TSP cam...but more or less, I want what is going to make the most power across the board...
Old Apr 20, 2012 | 07:48 AM
Tainted's Avatar
Have Pat G spec one out, what could be better?
Old Apr 20, 2012 | 08:20 AM
bww3588's Avatar
Avoiding that for now. This is only a temporary motor.
Old Apr 20, 2012 | 08:36 AM
87silverbullet's Avatar
The one from TSP looks like a good one. I don't like the one from Comp the exhaust side just doesn't look promising.
Take a look at some of the rectangular port cams from EPS. The smaller one has damn near no lope and it says stealth cam for the LS7. The cam that is the next size up is what would be recommended for a 370 cu in motor.
Here is a link to it
http://www.engpwrsys.com/index.php?a...&productId=110
Old Apr 20, 2012 | 09:38 AM
bww3588's Avatar
looks like a good cam...I cant seem to find any information on it, or any threads on here of anyone else using it to get personal opinions....
Old Apr 20, 2012 | 10:45 AM
bww3588's Avatar
edited my post removing the custom cam...added the EPS cam.
Old Apr 20, 2012 | 02:02 PM
99Bluz28's Avatar
You could do a custom spec cam with TSP, like a 231(lsl)/238(lxl) with a 113lsa.
http://www.texas-speed.com/p-161-com...-camshaft.aspx
Old Apr 20, 2012 | 02:13 PM
bww3588's Avatar
Looking for opinions on the 2 cams mentioned. Not going custom in any way...
Old Apr 20, 2012 | 02:15 PM
99Bluz28's Avatar
Then go with the EPS.
Old Apr 21, 2012 | 12:06 AM
bww3588's Avatar
I'm torn between the two because lately I have seen cams with less split and tighter lsa's making the same peak power, with more under the curve. Seems people are straying from conventional "wisdom" that ls3 heads need more split and wider lsa to work well...
Old Apr 21, 2012 | 12:16 AM
Johnnystock's Avatar
TSP gets my vote. I'm getting a 230-236 for my LS3 top end build
Old Apr 21, 2012 | 01:29 AM
Zmg00camaross's Avatar
I would call Geoff at EPS simple as that. He will get you squared away for sure.
Old Apr 21, 2012 | 04:40 PM
bww3588's Avatar
I agree...however, he is not going to give me any opinions between his cam and the TSP cam obviously.
Mainly what I am looking for here is a definitive answer between the cam with a large split and wide LSA, or a more traditional cam like the TSP cam.
basically a unbiased opinion that I wont get from any sponsors because they will try to sway me with their cams over other sponsors...
bww3588's Avatar
I'm going to order a cam tonight, so any help soon would be greatly appreciated.
Old Apr 21, 2012 | 05:38 PM
The Exhaust side needs all the help it can get so thats why I like the large split so the gases escape.
Old Apr 21, 2012 | 06:20 PM
bww3588's Avatar
Ok, Just ordered the 230/246. looking at a set of 1.8 rockers to go with them now...
Old Apr 21, 2012 | 07:03 PM
speedtigger's Avatar
Old School Heavy
That ought to have a wicked idle.
Old Apr 21, 2012 | 07:27 PM
bww3588's Avatar
Not too concerned with that...But a ground thumping idle is always a plus.
Old Apr 21, 2012 | 07:37 PM
bww3588's Avatar
I guess i'm the only one in the world that has this cam...I cant find any videos, dyno numbers, or even testamonials on it...I hope I made the right choice...
Old Apr 21, 2012 | 07:55 PM
litle88's Avatar
Damn bud, sorry I just saw this. I think for your app the 231/236 would of been the choice IMHO. Go to Camaro5 a lot of those dorks over there are using that cam with decent results on their ls3's with pretty decent results. What are your bore and stroke sizes?
