Calculate my engine compression please!
Old Apr 28, 2012 | 06:32 PM
camaro-coz's Avatar
Default Calculate my engine compression please!
Hey guy'z!
after the LS7 427 , LSX 441 I built for my T/A
I've decided to build a smaller engine , An engine with can be street used and street race with it... H/C ls1 with 400 shot
I'm confusied with my engine compression and as you guy's have the excess experience of some points that I'm not sure of , please help me with this.
59cc Patriot heads. stg 2 ls6
forged 347 , stock ls1 crank , 6.200 rods , -2cc flat top 3.905 diamond pistons.
0.0041 cometic head gaskets
111 lsa cam < wonderin' if that was needed
notice: when assembling my engine , I polished my block's "on the heads place surface. So a very thin layer was gone out.
How much will my compression be ? I wish it's around 11.7
extra question
how can I increase it until 12 ?
Thanks!
Old Apr 29, 2012 | 04:35 PM
camaro-coz's Avatar
anyone ?
Old May 4, 2012 | 11:57 PM
Jrp1978's Avatar
Default Little more info
To do this right !
Cylinder Diameter
Cylinder Diameter
Cylinder diameter
Stroke ( not rod size )
Head cc
gasket thickness (think you have few to many zeros
piston cc ( flat top , dome , reverse dome cc)
Deck height ( if the piston at tdc is in or out of the whole !
Some will even use gasket bore size!
To get more compression
Thinner Gasket
Deck the heads to reduce cc !
Ummm you can have the block deck to have piston come out .005 or so !
Crank shaft stroke !
But what you have know its really hard to tell you where you are !
Old May 5, 2012 | 12:01 AM
Jrp1978's Avatar
Default Best guess
Not 100 % but 11.6 would be a close guess!
Changing to .030 would get you almost 12
But if you are 11.6 you are not get see much benifet from a 200 dollar set of gaskets and not sure they even make them for your bore !
Old May 5, 2012 | 12:03 AM
Jrp1978's Avatar
Default Opps
-2 cc pistons will get you 11.2
Old May 6, 2012 | 01:17 AM
camaro-coz's Avatar
Thanks for the replies bro!
well ...
A mechanic calculated it and the compression it almost 11.7
Old May 7, 2012 | 05:27 PM
Pumba's Avatar
well ...
You need to provide us with more data.
Go to this URL and fill in the blanks with data: http://www.kb-silvolite.com/calc.php?action=comp
Stop guessing and get the data.
Also, don't make your head gasket any thinner until you know the piston's deck height.
Old May 10, 2012 | 01:13 AM
camaro-coz's Avatar
My piston deck hight is 0.10 under I'll check out the URL
