ls2 want to touch 500
Old Apr 29, 2012 | 02:29 PM
ls2ginger's Avatar
Default ls2 want to touch 500
i got an 05 ls2 gto currently running the tsp tsunami cam with pacesetter lts vararam ported ls2 tb. just bought a fast 102 and am looking at the prc 2.5 ls6 heads due to my budget . any one have a simaler setup or advice on if this should work out ? i dont care about drivability i just want teh car to run hard i drive it on the street but its not a dd
Old Apr 29, 2012 | 03:50 PM
ls2ginger's Avatar
anyone ? i want to get kicked out of the track
Old Apr 29, 2012 | 04:29 PM
Tainted's Avatar
You want to get kicked out? Thats a smart idea...
Search in the dyno results area for the tsunami cam and see what people are making.
Old Apr 29, 2012 | 04:48 PM
ls2ginger's Avatar
anything below 11.4 requires a cage i dont have one so id get kicked out
Old Apr 29, 2012 | 06:52 PM
Gray86hatch's Avatar
Flowtech induction has those cars figured out.
I would contact them you may not need anything other than a new cam.
Tim
Old Apr 29, 2012 | 07:17 PM
ls2ginger's Avatar
ill check them out thanks!
Old Apr 29, 2012 | 07:55 PM
gs462's Avatar
With a fast 102 and those heads and a decent cam youll make way over 500 FWHP
Old Apr 29, 2012 | 08:02 PM
ls2ginger's Avatar
currently runnig tsp tsunami 235/240 .648/.609 i hope what you say is true! aha that would be a nice suprise
Old Apr 29, 2012 | 09:09 PM
Imstock2's Avatar
Your going to need 500 rwhp not fhp to break mid 11's
Old Apr 29, 2012 | 09:14 PM
COPO9560's Avatar
125 shot of nitrous should get you kicked out, assuming you gain adequate traction. Probably least cost and easiest way to get there with what you now have.
Old Apr 30, 2012 | 10:01 AM
87silverbullet's Avatar
Don't know about that one. Many cars have done mid 11's and not even near 500 rwhp.
Old Apr 30, 2012 | 12:35 PM
Tainted's Avatar
+1. My h/c/stall trans am could get into the 11s with some ported stock heads and 228r. Did have full suspension, and a little less weigt though and that always helps when you get a good launch
Old Apr 30, 2012 | 12:52 PM
One of my buddies that had a 99 camaro had a full bolt on car that ran 11.86. No internal mods what so ever. Stock heads, stock cam, 4400 stall, 4.10 gears. Full weight.
Old Apr 30, 2012 | 10:18 PM
ls2ginger's Avatar
Yeah I'll also have 3.91s I'n the rear I'll be I'n 26x10-15 et drags
